Thread: stupid fuel rail
Results 1 to 7 of 7
  1. #1 stupid fuel rail
    GXP Level Member ryangtp89's Avatar
    Maine
    Soo i wanted to see if my cylinder 1 fuel injector is messed up soo i switched it with the cylinder 2 injector soo i did that and bolted down the fuel rail and now i cant really gewt the injectors on the fuel rail tight they r loose. Is their another o ring or something ??? It's not leaking or anything.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: stupid fuel rail
    there are two o-rings. one on top and one on bottom for each injector. when you pulled it out you probably left one sitting in the fuel rail.
  3. #3 Re: stupid fuel rail
    Maine
    Yeah i bet your right! Soo i drove it home and it wasnt too bad but you can tell its miss firing and the tcs is stuck on and after driving it it likes to idle super high like it stays at 2k when u first start it up it idles at 1500 do i need to do a tps learn ?? Theres the code i wanted to let u guys know about ill edit later.
  4. #4 Re: stupid fuel rail
    2k idle? what?
    vacuum leak from your injector o-rings....
  5. #5 Re: stupid fuel rail
    St. Louis Mo.
    Moved to its correct location.
    James Shafer
    St. Louis MO
  6. #6 Re: stupid fuel rail
    Barksdale AFB, LA
    There's no such thing as a TPS relearn. You need to fix your vacuum leak.
    2009 Subaru Impreza WRX STI
  7. #7 Re: stupid fuel rail
    What they said...or get a new TPS
  1. Fuel rail pressure?
    By GINOSGTP in forum General Tech Discussion
    Last Post: 05-06-2009, 12:52 PM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. fuel rail
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2008, 01:09 PM
  4. Fuel rail mods for intercooler?
    By bevernden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2008, 11:15 AM
