Thread: boost problem...
Results 1 to 17 of 17
  1. #1 boost problem...
    elmont, ny
    I have a 1998 GTP. For a while I've been getting half boost only when the car is at normal operating temp. When the car is cold, I'm able to get full boost. I've replace the bypass valve, put a mech. boost gauge, no vac leaks, rebuilt the snout on the SC, new belts, new SC tens, and still the same problem. Does anyone have any ideas? Would a clogged cat have anything to do with it? Canister Purge Valve? EGR valve? This is driving me crazy!!
  2. #2 Re: boost problem...
    you know when your car is below running temperature that the knock sensors havent turned on yet so you are actually experiencing true detonation instead of the car being able to pull timing to stop it?
    with a clogged cat the car would be a super huge dog. EGR isnt active when youre into the throttle hard.
    what is it reading for boost? if it is reading about 6-7 pounds then that is all that the stock setup makes..
  3. #3 Re: boost problem...
    elmont, ny
    the gauge is reading 4 psi and like 7-8 cold
  4. #4 Re: boost problem...
    sounds like your boost bypass is messed up, but you said youve replaced it. have you tried to take the lower vacuum line off the BBV and ending the vacuum line at the FPR?
  5. #5 Re: boost problem...
    elmont, ny
    i completely eliminated the bypass by capping it off. still same thing.
  6. #6 Re: boost problem...
    you dont cap it off, you leave it open to the atmosphere.
  7. #7 Re: boost problem...
    elmont, ny
    Ill try that, are there any adjustments that i have to make on the valve?
    thanks
  8. #8 Re: boost problem...
  9. #9 Re: boost problem...
    elmont, ny
    will do. thanks
  10. #10 Re: boost problem...
    elmont, ny
    Pulled off the lower vac. line on the bypass valve, and that fixed the problem. now what do i do to fix the problem? The bypass valve is new. any ideas?
  11. #11 Re: boost problem...
    Feb 2009
    Toronto, Ontario
    I am having the same problem.. I just got a HPtune done. I will try this. Thanks!
    All Motor Is Nice, But I'd Rather Be Blown!
    1999 GTP , Bronzemist, FWI, Resonator and U bend delete, 180* T-stat, HPTune.
  12. #12 Re: boost problem...
    GTP Level Member Scimmia's Avatar
    QCA, IA
    It means the solenoid is bad or there's a problem with the wiring. Check the wiring first some people find corroded contacts or loose connections.
    I have a couple of extras laying around, can't guarantee they're good, though, as I've never run them.
    2001 Buick Regal LS - Almost Stock
  13. #13 Re: boost problem...
    elmont, ny
    and if i eliminate the sol. and run the vac. straight to the bypass will that work?
  14. #14 Re: boost problem...
    QCA, IA
    Not exactly, to eliminate the solenoid, you would just leave the bottom of the actuator open to atmosphere and cap off the vac line after the FPR. Be aware, though, the computer uses the solenoid for traction control and for bleeding off some boost at the shifts, so you'd want to keep an eye on things to make sure you don't run lean or anything during shifts. The computer MAY also throw a code, but that seems to be hit or miss.
  15. #15 Re: boost problem...
    elmont, ny
    could that be a reason why my traction control light/abs is on?
  16. #16 Re: boost problem...
    QCA, IA
    I think it throws an SES light, not TC/ABS. TC/ABS is a bad wheel speed sensor the vast majority of the time.
  17. #17 Re: boost problem...
    Feb 2009
    Toronto, Ontario
    I just took off the lower vacuum line and my boost problem is gone.... after the BBV.. what part is it called that the line goes to?
  1. Stuttering problem under heavy boost
    By 02gtp2708 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2009, 12:35 PM
  2. boost lag problem
    By ahemione in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2009, 12:12 PM
  3. boost??
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 06:59 AM
  4. problem with ANY boost
    By xwire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2008, 01:43 PM
  5. More boost?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-25-2008, 12:33 AM
