Thread: question about nitrous
Results 1 to 20 of 29
  1. #1 Re: question about nitrous
    Donating Users blowfishRus6's Avatar
    g.a.
    BUT since we got a tunner expert in here...
    do you need to tune for spray?? what kind of tunning??
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #2 Re: question about nitrous
    Banned
    oswego
    Quote Originally Posted by blowfishRus6 View Post
    Here's the essay...
    Yea, tuning for anything over a 50shot is highly recommended (if it's a wet shot, dry shots requiring tuning no matter what the shot is IMO) since timing is important to pull. I wouldn't recommend spraying a car unless it has at a lot of exhaust work. Spraying with plog-dp, or stock mani-dp combo's is just way to restrictive. Headers at the minimum either running to a nice flowing exhaust or even better, a cut out. Intake, pulley, blowers, ported manifold, ect, aren't needed with nitrous. The only mods you really need are rockers on the exhaust side and the freest flowing exhaust you can get. The better the exhaust flows the more efficient the nitrous will be. Spraying through the blower is a waste since the nitrous will heat up and expand thus making it less efficient but for some that's the only choice.
    the whole idea is to get the nitrous to the cylinders as cold as possible and have more than enough breathing room to get it out. Since nitrous goes in the liquid form (on an ideal setup) nothing is needed to help it get "in" but once it burns a 100 shot will have the same exhaust volume as a 500 c/i motor, hence the required exhaust mods.
    Now, as for tuning... I was WAY too paranoid about timing last year when i ran my car. I was new to tuning, new the gp's (only 4-5 months) and new to actually racing a quick car. I pulled back 8* of timing and only ran 12* at WOT on my 75-100-125 shot. I actually only need to pull about 4-5* if that. It was a dry shot so i had to compensate for the fueling with my injectors. What i did for that is just scale the hell out of my maf adding up to 50% to the WOT cells to make up for the fuel needed. In that tune the car was useless unless the nitrous was sprayin, hence why i'll be running a wet shot setup this year. Even with everything against me i somehow was able to squeak off some 11 second passes and 115-116 mph. This year with the higher compression, cam, ect i should be able to match the mph and et easily on a 50-75 shot. With that shot i can make 12-15 passes with out a problem on one bottle which i don't plan on doing anyways, that's just way to hard on these transmissions which are obviously the weak point hands down.
    Nitrous isn't for everyone but it's very cost effective IMO. I don't know where you guys are getting $50 per bottle fill but i usually pay about 25-30 depending on where i go for a full 10lb bottle. I don't make 100,000 passes at a track and i don't street race so i c no reason to have 11 second power all the time but to each is his own i guess?
  1. Nitrous, Dry or Wet?
    By japslpr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2009, 02:32 PM
  2. Nitrous on my GT
    By gpracing in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-26-2008, 12:01 PM
  3. Nitrous (ZEX)
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-25-2008, 12:19 PM
  4. Another Nitrous Question... Dry vs. Wet
    By Iron Indian in forum Off Topic Discussion
    Last Post: 01-28-2008, 03:37 AM
