Disconnect the battery
remove the back plug wires to move them out of the way
remove the alternator and the black alternator bar (most do not put the bar back on)
Loosen the alternator bracket but don't remove the bolts
remove the MAP bracket.
I removed my engine bracket(s) at this time and put them on the shelf.
I think that this should give you the access you need.
Now would be a good time to replace the coolant elbow though. If you do this, go ahead and remove the alternator bracket as it will make removal and installation of the VC somewhat easier.
