Thread: Improvement Questions.
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 Improvement Questions.
    Ridin' the Blue IrishNation24's Avatar
    San Diego, CA
    alright guys, i have a few questions about getting a little more power out of my 2001 GTP. right now the car is completely stock. so it has 240 hp, 280 ft-lbs torque, as you all know. it runs 0-60 in about 6.5, as far as the rest goes, i don't know because i haven't done any testing with it. what i am wanting to do is increase the hp, and TORQUE to get it to run a little faster, to be able to back up its looks a little better. i'm not the most mechanically inclined person, i just have the general knowledge about it.
    question: how much smaller of a pulley can i put on, without putting to much pressure on the engine and supercharger. and how do i know what the engine and supercharger handle?
    so if i wanted to put say a 3.5" or a 3.4" pulley on it, would adding a borla exhaust and cold air intake be enough. or would i also need to upgrade the headers? also a few other questions, what about putting in a performace chip( i dont actually know how to do that or where it goes, but i've heard of people doing that to get a little more power.) another question, i've read some other posts about exhaust systems, and they were talking about a downpipe and ubend, what is that? and ive seen post about scanning for KR, what is KR?
    so overall would adding:
    borla exhaust
    cold air intake
    header upgrade
    performance chip(maybe)
    be enough to handle a 3.4 or 3.5" pully.
    as i said, all i'm wanting to do is add a little more power to get it closer to 300 hp/tq and closer to under 6 second 0-60. i just want it to be able to back up its looks a little better (i will be adding a ram air hood, new wheels, chrome grill, and a new paint job with effects, have already put LED taillamps, and clear corner lights and new fogs). right now it has 72000 miles on it. its in pretty good shape, haven't had any mechanical problems since i got it with 50k on it. i do all the routing maintenance myself, and i dont mash the pedal all the time(just half the time, LOL. and when im in the front of the line). i dont want to put too much strain/pressure on the engine, and i dont have the money to upgrade everything, but i dont want to anyway. just a little more power is all i need. ANY comments or questions, and for sure any suggestions are welcome. THANKs for your time.
    also, to anyone who has done exhaust system, what have you done? im looking for a deeper and louder sound, but not like a rice wagon cherry bomb
    and does the downpipe go in place of the u-bend?
  2. #2 Re: Improvement Questions.
    First off...thanks for the book
    KR is bad lol...read here: http://www.grandprixforums.net/f18/w...here-1507.html
    Another thing is these cars don't have "chips" they have PCM's and they are tuned. You can get one from:
    3800 Performance - high performance aftermarket car parts for your Grand Prix, Monte Carlo, Impala, Regal, Bonneville, and V6 F-body!!
    INTENSE-Racing.com - G8, Grand Prix, Bonneville, Regal, L67 3800 Supercharged Performance Products.
    :: Overkill Motorsports ::
    Any of those are great PCM's...just be sure not to buy PCM's from ZZP as they don't have a reliable tuning source anymore. They are junk.
    Pulley drop...go read some threads...that is the last basic bolt-on mod you want to do.
    As mods go...if I could do it all over again...I would get in any order really...
    180* Thermostat
    Autolite 104 Spark Plugs
    PRJ 10.4mm Wires
    SLP/ZZP/Pacesetter/SS Autochrome Headers (Any of them work)
    Some form of Intake (K&N is junk and the SLP/Wizaird/MSP aint great either)...make your own for $50 or so...
    Tuned PCM of your choice.
    3.5" or 3.4" Pulley. If you want to mod past this then opt for the ZZ Performance Modular Pulley System.
    Hope this helps.
  3. #3 Re: Improvement Questions.
    Donating Users blowfishRus6's Avatar
    g.a.
    and just remember thats crank horsepower. its not putting that down to the wheels. maybe 200ish to the wheels. but im sure a basic 3.4/3.5 set up will net you the gains your looking for.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #4 Re: Improvement Questions.
    San Diego, CA
    how much smaller of a belt would i need to use the 3.4"
  5. #5 Re: Improvement Questions.
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Quote Originally Posted by IrishNation24 View Post
    same stock size belt will work
  6. #6 Re: Improvement Questions.
    San Diego, CA
    Quote Originally Posted by stlmo_gtp View Post
    how would that work i mean wouldn't it be to loose?
  7. #7 Re: Improvement Questions.
    Barksdale AFB, LA
    You're supposed to go to a smaller belt with a 3.4.
    2009 Subaru Impreza WRX STI
  8. #8 Re: Improvement Questions.
    St. Louis
    really? i heard that you could use the same belt on a 3.4
  9. #9 Re: Improvement Questions.
    Barksdale AFB, LA
    I'd be afraid the tensioner wouldn't be applying enough tension.
  10. #10 Re: Improvement Questions.
    St. Louis
    true i could see how you may end up with the belt slipping a bit
  11. #11 Re: Improvement Questions.
    San Diego, CA
    Quote Originally Posted by Sabrewings View Post
    so how much smaller of a belt. im not even sure what the original belt size is.
    and one more question. i've been looking on zzp and other places, and theres so much damn information i don't even know whats right anymore. if i put a 3 inch exhaust system from zzp or anywhere else, does that delete the ubend and add a new downpipe, or do i still have to do both of those things seperately. and would i need to add headers, cuz the stock are only 2.25" aren't they? i sound like a idiot, but im just getting really confused
  12. #12 Re: Improvement Questions.
    St. Louis
    this is what i found on ZZP
    667 stock S/C belt for GTP, GS, SS
    658 GTP, GS, SS S/C belt for 3.5-3.25 pulley
    650 GTP, GS, SS S/C belt for 3.2-3.0 pulley
    ZZ Performance
  13. #13 Re: Improvement Questions.
    Barksdale AFB, LA
    3" exhaust is a waste. And no the catback exhaust doesn't affect the u-bend. The u-bend is part of the downpipe.
    Downpipes are either sold with a set of headers or sold separately if you want an upgraded replacement to the stock.
    The most constrictive points in the stock exhaust system are the stock downpipe (to include the u-bend) and the front manifold. The catback is fine as it is. Depending on how far you want to go in modding you could get a downpipe and Plog. If you want to go further than you should get a set of headers.
    Here is a link that shows the entire stock 3800 exhaust. Should help you visualize some of these parts:
    http://www.naioa.com/v2/modules.php?...hlight=exhaust
  14. #14 Re: Improvement Questions.
    San Diego, CA
    thanks for the post! pics really help. and just to be sure, PLOG is basically and upgraded manifold, but not as good as headers right? and is the crossover pipe fine as is, or would i need to upgrade that with the headers, cuz the one in that picture doesnt even look right. sorry to keep adding questions, just tryin to learn.
  15. #15 Re: Improvement Questions.
    St. Louis
    that is correct a PLOG is basically a ported manifold which is a upgrade but not as good as headers, if you get headers they come with the crossover to connect the front and rear, but if you go with a PLOG you have to order one separately although i know some people that get a PLOG and just keep the stock crossover
  16. #16 Re: Improvement Questions.
    Barksdale AFB, LA
    The crossover is fine if you just want to get a bigger DP and the Plog. Not sure what you think isn't right about the crossover in the pics since they're all the same. There is no upgraded version available (only headers if you want to go that route). I currently have a ceramic coated crossover to help keep the radiated heat down and to keep the exhaust hot as it leaves the engine bay.
  17. #17 Re: Improvement Questions.
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    My best advice to you is to read, read, read, read, read, and read some more. Then read again. You need knowledge to do these cars properly. Then get a scanner before you do anything. I know, it sucks because it does not make the car faster. But, you will use it and it will keep you from blowing the damn thing up. There was a previous post that had a basic list to run a 3.4/3.5 pulley SAFELY. You may not need headers. I just installed a PLOG(If you get one, get the stainless steel PLOG) and it helped the top end and lowered my KR to a few blips of 1*. I will end up with headers, I know it, but that is because I want to drop to a 3.25 later on. But as far as the 3.4, What I have to support it is working for me.
  18. #18 Re: Improvement Questions.
    San Diego, CA
    i think when it comes time to do it, ill do headers, dp, ubend delete, and borla or magnaflow exhaust. probably take it to a shop and tell em that and see what they say.
    where can i get a scanner, or is it pretty cheap to just take it to a shop to do it?
  19. #19 Re: Improvement Questions.
    Barksdale AFB, LA
    If you get headers, it comes with a DP and thus the u-bend delete.
    You'll want something permanent in your car so you can keep an eye on things. Either an Aeroforce or Scangauge II is the sort of thing you want.
  20. #20 Re: Improvement Questions.
    San Diego, CA
    i couldn't find a post specific on how to install one of these. is it just something you plug in somewhere on the car and thats it?
  1. HV3 questions...
    By whitelightnin04MC in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-23-2010, 11:43 PM
  2. Few Questions
    By shape275 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2009, 09:10 PM
  3. A few questions
    By Shaunk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2009, 09:36 PM
  4. pcm questions - need help
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2009, 05:07 PM
  5. IPW questions
    By fst in forum PCM Tuning
    Last Post: 01-11-2008, 06:44 AM
