Thread: HELP-metallic tapping sound, what could it be?
Results 1 to 20 of 21
  1. #1 Re: HELP-metallic tapping sound, what could it be?
    Barksdale AFB, LA
    Make sure your oil level is good. It could be a lifter that's starting to collapse.
    2009 Subaru Impreza WRX STI
  2. #2 Re: HELP-metallic tapping sound, what could it be?
    changed the oil and the old oil looked fine and the level was within the dotted lines. new oil is the same i've been using, mobil 5000 10w-30, but i tried switching from the ac delco pf-52 to the oem pf-47 but still no change. oil level with the fresh oil is again within the dotted lines.
    edit-did anyone listen to the sound? i heard dubob's sample clip of a local having loud lifter ticking that was failing, but is this a smiliar scenario?
  1. mm no its not purple its midnight blue metallic stupit
    By slyon8tor in forum Introductions/Noob Questions
    Last Post: 02-04-2011, 05:02 PM
  2. Bronzemist metallic Owners
    Last Post: 07-22-2009, 01:34 AM
  3. loud tapping noise
    By blown98gtp in forum General Tech Discussion
    Last Post: 03-04-2009, 03:40 PM
  4. Tapping power from Amp.
    By m0ng00se in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2008, 07:57 AM
  5. HELP: tapping noise!
    By fst in forum General Tech Discussion
    Last Post: 08-28-2008, 10:46 PM
