Thread: HELP-metallic tapping sound, what could it be?
Results 1 to 20 of 21
  1. #1 Re: HELP-metallic tapping sound, what could it be?
    broken spring? go ahead and pull off the valve cover and check...
  2. #2 Re: HELP-metallic tapping sound, what could it be?
    i took off the rear and front valve covers but did not notice anything wrong with the springs nor the rockers. although i dont have a 28mm socket to manually crank the crank pulley i tried pushing down on the rockers on the pushrod on all of them to see if any of them would sink, to test whether it would 'collapse', but none of them did. upon start up i noticed the lifters tick a bit louder than usual and after driving til the motor warms up and i start eharing the tapping sound, it seems to go in sync with the misfire/lopiness of the vs cam. is it possible a lifter(s) would go from a loud tick to a metallic tapping sound?
  1. mm no its not purple its midnight blue metallic stupit
    By slyon8tor in forum Introductions/Noob Questions
    Last Post: 02-04-2011, 05:02 PM
  2. Bronzemist metallic Owners
    Last Post: 07-22-2009, 01:34 AM
  3. loud tapping noise
    By blown98gtp in forum General Tech Discussion
    Last Post: 03-04-2009, 03:40 PM
  4. Tapping power from Amp.
    By m0ng00se in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2008, 07:57 AM
  5. HELP: tapping noise!
    By fst in forum General Tech Discussion
    Last Post: 08-28-2008, 10:46 PM
