Thread: What should i use?
Results 1 to 20 of 26
  1. #1 What should i use?
    May 2008
    McHenry IL
    my coolant looks gross! dark brown and black crap in it ewwww that the 1 thing i never changed since i got it... well its DUE! this weekend ill flush her. theres a valve on the radiator to drain the coolant and flush it right?? what should i run new in it? i hear dex cool is DEATH COOL lol. what is the best for me? i am not that knowledge able about cooling so if anyone can shoot me some pointers i would appreciate that
  2. #2 Re: What should i use?
    Barksdale AFB, LA
    Get the yellow Prestone universal coolant.
    2009 Subaru Impreza WRX STI
  3. #3 Re: What should i use?
    May 2008
    McHenry IL
    is that good stuff sabre =p
  4. #4 Re: What should i use?
    Nov 2008
    Searcy,Arkansas
    Tip....Make sure you bleed the air out when your done!!!! Some people forget or didnt know you had to do that!!!
  5. #5 Re: What should i use?
    GTP Level Member dstout's Avatar
    ky
    I just went to the shop my boss uses and they did a flush, dexcool is suppose to be good for 100,000 miles and my fluid looked like muck. It was too cold out to do it myself and too much snow.
  6. #6 Re: What should i use?
  7. #7 Re: What should i use?
    May 2008
    McHenry IL
    yeah green stuff it is ha
  8. #8 Re: What should i use?
    Barksdale AFB, LA
    Run the yellow. It won't be come corrosive on aluminum (like green does) and won't ever sludge up like Dexcool. It's superior to both.
  9. #9 Re: What should i use?
    I run the yellow Prestone like Sabrewings.
    I had fine flushed and filled @ Jiffy Lube. Know the kids there and I trust them doing something like that...now changing oil...thats a different ball game.
  10. #10 Re: What should i use?
    May 2008
    McHenry IL
    jiffy lube is a JOKE! and a disgrace to the automotive world.
  11. #11 Re: What should i use?
    green is corrosive? whaaaaa? how so, it is just like water..
  12. #12 Re: What should i use?
    Barksdale AFB, LA
    In a well formulated US green coolant, phosphate works to provide the benefits you describe. However, if the silicate is not well stabilized and the silicate protection is lost for an aluminum head, a phenomenon know as either "hot surface corrosion" or "aluminum transport deposition", depending on what car company you are talking to, can occur.
    In this form of corrosion, the aluminum is corroded from the hot spots in the head, usually near the exhaust ports, and then reacts with the phosphate in solution to form aluminum phosphate. The aluminum phosphate is then deposited on a cool surface in a heat exchanger leading to over heat problems.
    It has been reported as either a gelatinous precipitate that blocks the tubes or as a thin ceramic deposit on the radiator (original finding of the problem when Chrysler was testing VW engines to use in Omni/ Horizon in the late 70's) in the shape of the fan. If you write the chemical reactions that occur when the aluminum phosphate is precipitated, you will find that caustic is generated. The corrosion process then increases exponentially.
    More On "Antifreeze: Red or Green?"
    That is the very reason Dexcool was created. It can affect anything aluminum in the cooling system (LIM, blower housing, water pump, etc). Now we have the yellow, which is better than both.
  13. #13 Re: What should i use?
    hm..maybe ill switch over on my new block. hell will freeze over before i go back to dexcool.
  14. #14 Re: What should i use?
    Jersey
    i run dexcool still, when i flush i will still run dexcool
    16' wrx sti- stock
  15. #15 Re: What should i use?
    Barksdale AFB, LA
    I never had a problem with Dex. I haven't flushed it all out but after doing my LIM gaskets and now my top swap there's very little Dex left. I do put in the yellow as a replacement though.
  16. #16 Re: What should i use?
    Quote Originally Posted by GTPJOE90 View Post
    So is taking the resonator out of a 3800 powered car.
    Quote Originally Posted by Sabrewings View Post
    I thought you weren't supposed to mix dexcool?
  17. #17 Re: What should i use?
    Barksdale AFB, LA
    The Prestone yellow is universal. Works with all other coolants. It's really great stuff.
  18. #18 Re: What should i use?
    Yellow is really the way to go.. Dont even have to worry about left overs of Dexcool like you would if changing to green..
  19. #19 Re: What should i use?
    Jersey
    hmm maybe ill return the 4 or 5 jugs of dexcool I bought and get yellow.
    16' wrx sti- stock
  20. #20 Re: What should i use?
    Quote Originally Posted by 99prixgt View Post
    Then buy some beer with the money you saved
