Thread: Diagnosing corrosion on coil pack terminals
Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
  1. #41 Re: Diagnosing corrosion on coil pack terminals
    Oklahoma
    Well I got two tubes of the stuff coming. I'll have to experiment a little and see what I can come up with in the way of information on its affect of a connection.
  2. #42 Re: Diagnosing corrosion on coil pack terminals
    Hoffman/Schaumburg, IL
    In school we always called this ignition system "Waste Spark" because the spark out of one of the plugs is always "wasted"
    Our ignition system is why you can't find a miss fire by pulling just the wires and not correctly grounding the cables, it creats an open circuit with 30,000+ volts, it is going to find a path back to the coil, through the wire or back through the secondary windings, or it can jump the coil housing. this can F-up your ignition system, just my word of warning while we are all on this subject
    Anybody remember carbon tracks in distributors, they appear on our coils too....
  3. #43 Re: Diagnosing corrosion on coil pack terminals
    Oklahoma
    You know, Im glad you defined waste spark, cause I did not know that was why they called it that. Thank you.
  4. #44 Re: Diagnosing corrosion on coil pack terminals
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    hrmmmm
    i coulda swore that the info i posted had the wasted spark info in it... have to double check that.
  5. #45 Re: Diagnosing corrosion on coil pack terminals
    Oklahoma
    I dont think it used the term 'waste spark' or if it did it didnt register with me. But looking at what you posted, it essentially says the same thing when it talks about the second spark being fired but the cylinder being open to the atmosphere.
  6. #46 Re: Diagnosing corrosion on coil pack terminals
    SW Chicago Suburbs
    eh, it was in some further documentation that was with the part that i posted here...
  1. lighter coil pack bracket?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 08:29 PM
