Thread: open air filter in engine bay
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 open air filter in engine bay
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    if i dont remove the whole air box and just the lid will the comp. inside just fall out or is it strapped in ? i know this is a STUPID question but i would rather ask instead of tear it apart then put it back together and go buy a filter then go home and tear it apart again . so is the comp strap inside the air box or is it sorta just loose in there ? i figure i will run just a open air filter where the lid use to be until i can afford either the k&n intake or maybe some other brand . help please thanks .
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  2. #2 Re: open air filter in engine bay
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by bayareagtp View Post
    As I recall the computer sits in the back part and one of the mounting nipples is on the bottom of that piece. I would either gut the box or leave it be. IMO openign it up to the underhood temps is not a good thing. If you like I can try to shoot some pictures of my gutted airbox this weekend. Its only about a two hours job to gut, just messy.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: open air filter in engine bay
    Oklahoma
    Indeed, if you dont mind, send me some of those pictures. I have an air box I started work on but never completed and Id kinda like to get an idea of how to go.
  4. #4 Re: open air filter in engine bay
    Milpitas , Ca.
    yea please post some pics or maybe even a how to . thanks ! yea i wasent sure if the comp exposed to the open engine temps was gonna be so good .
  5. #5 Re: open air filter in engine bay
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    on a related note, is there an oem option for a pcm hold down for a 97 PCM? the s-10 one says it wont fit the 97's pcm. --i'm employing some zip ties at the moment, but that's not a good long-term solution.
  6. #6 Re: open air filter in engine bay
    Milpitas , Ca.
    if you go to 3800performance.com and look at their air intakes they have a tray for $70.00 . if you look at the install instructions you can get a pretty good idea of how make 1 your self .
  7. #7 Re: open air filter in engine bay
    St Louis MO
    Yep but I thought you were talking about leaving part of your stock airbox in there. If that is the case then that tray or the $16 GM Blazer PCM tray won't work. As I recall, people with FWI buy those.
    And for those curious, I'll try to get those picures of the gutted airbox tonight.
    2010 Camaro SS LS3
  8. #8 Re: open air filter in engine bay
    Milpitas , Ca.
    oh no sorry i was posting back to toastys comment .
  9. #9 Re: open air filter in engine bay
    Milpitas , Ca.
    sorry i need to learn to quote the comment i am commenting about . yea i was tring to keep half of the air box in the car so i didnt need to buy a tray .
  10. #10 Re: open air filter in engine bay
    St Louis MO
    Got ya. Yep I don't believe that would work or look good either.
    2010 Camaro SS LS3
  11. #11 Re: open air filter in engine bay
    SW Chicago Suburbs
    i need to do some junk yard lookin or somethin. there HAS to be a less expensive pcm tray that will work for the 97 style pcms. -- i see a tray out of a first gen aurora fits that style pcm, but would have to cut it up a bit and drill some holes in it for it to work.... but doable.
    gotta think that there's something out there, but wont find it without a good junkyard.
  12. #12 Re: open air filter in engine bay
    St Louis MO
    Sorry I didn't get these for you last night as I sadi, but the camera is the wifes which I couldn't find. Anyway I remembered I emailed these to someone a long time ago, but had to figure out which computer I put them on. Here is the thread link.
    http://www.grandprixforums.net/f18/g...html#post13689
    If you pull your airbox out and look at it, you'll see how much of a difference this can make. It is also NOT visible to the epa, if that is a concern.
    2010 Camaro SS LS3
  13. #13 Re: open air filter in engine bay
    NE Ohio
    my k&n intake has a pcm tray built in..
  14. #14 Re: open air filter in engine bay
    Milpitas , Ca.
    Quote Originally Posted by kyle99gtp View Post
    how do you like your k&n ? everyone tells me bad thing about it .
  15. #15 Re: open air filter in engine bay
    SE Level Member phat_ridegt's Avatar
    Ottawa, IL
    the k&n's arent 'bad' but if they are overoiled, they can cause poor MAF readings and major tuning problems.
    i have tested a few intake systems, and the best bang for your buck, is to pull the stock air box, and just run an open cone in the engine bay. just need to secure the pcm down (or wrap it in some towels), and there ya go.
    this has been beat to death, but i have seen WAY more airflow with the warm air intake than the cai. maybe for a basically stock car, the CAI would be best, but i wouldnt bet on it. heres mine, and it works very well.
    XP|I/C'd GEN V|ZZP TRANS|
    11's or BUST
  16. #16 Re: open air filter in engine bay
    St Louis MO
    Why did you buy an IC?
    2010 Camaro SS LS3
  17. #17 Re: open air filter in engine bay
    Elk Grove Village, IL
    Quote Originally Posted by IndeedSS View Post
    Its questions like that that irk me.
    Why do the slower cars swear by CAIs and the faster cars open cone??
    Flow>temp in this case.
  18. #18 Re: open air filter in engine bay
    St Louis MO
    Quote Originally Posted by Fish View Post
    Look outside of our group and see what the faster higher end cars run. Now if you are talking the track on and IC car with the headlight out and the weatherstripping off then ok. However, on an average car an open cone is.... arrggghhh. Anyone that has been under their hood when the fans kick on will quickly realize where that 180-220* air is going. Cold air flow is better than hot air flow when it comes to performance anytime. Very few cars are starving for air with a CAI or FWI. You can't always go by the MAF either. There is a point where, a little less flow with a colder intake charge will make more power than more flow of hot air. Someone that knows engine thermodynamics please explain the effects of colder air in the intake charge versus hot air.
    2010 Camaro SS LS3
  19. #19 Re: open air filter in engine bay
    St Louis MO
    Here is something Kenne Bell has on their website about Hot Air Intakes and as far as know they don't sell CAI
    http://www.kennebell.net/techinfo/ge...AirWARNING.pdf
    2010 Camaro SS LS3
  20. #20 Re: open air filter in engine bay
    How about someone with common sense.
    Cold air is more dense which leads to more O2. This is why we have to pulley up in the winter time since it is rich with oxygen. More oxygen means more boom in the cylinder. This also equates to more fuel needed.
    Warmer air has less O2 which means it wont be as big of a boom. This means you have to pulley down to get the same amount of air as if it was colder.
    However, a 30* difference in IATs (contrary to popular belief, the IAT#s wont be the same as the underhood temp.) will make a minimal difference. If your worried about the PCM pulling timing, dont worry.
    Does it matter what the faster higher end cars run that arent ours?? We arent modding those cars. We are modding ours.
    Kenne Bell blowers are a total different monster then our puny M90s. They compress within the blower and get hot there. Also, there is no "proof" that it is horrible. Just stating that the warranty wont be valid if you use a HAI. Its their discression.
  1. acdelco pf52 oil filter
    By nemesis in forum General Tech Discussion
    Last Post: 12-22-2008, 02:17 AM
  2. where the heck is the oil filter?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2008, 08:47 PM
  3. engine will start only if
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2008, 07:34 PM
  4. profanty filter set to high
    By chrisgtp in forum Forum Bugs/Suggestions
    Last Post: 12-29-2007, 12:11 AM
