Thread: Whinny noise from Alternator side??
Results 1 to 14 of 14
  1. #1 Whinny noise from Alternator side??
    Donating Users Burgundyman's Avatar
    1998 GTP 4-door
    Well, I am at it again with changing noisy idlers and pulley. I noticed a high pitch noise, which seems to be coming from the alternator or perhaps the tensioner pulley right below it. My lights are not dimming or any indication of an alternator failure. I would hate to change a good alternator. I have recently changed the idler and belt tensioner pulleys used on the S/C belt. The loud squeals went away as the noise definitely came from the S/C belt operation. Any thoughts about changing the alternator ($250.00 GM OEM). The belt tensioner pulley on the alternator belt is only $35.00 GM OEM. The noise just started. I must also add that I had washed the engine and many times before that and never had squealing problem. Took it on a long drive hoping any moisture trapped would have disappeared after reaching highway speeds. Still the same squeals from the top where the alternator is located.
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  2. #2 Re: Whinny noise from Alternator side??
    could be both actually. what i thought was my altenator. it was the belt tensioner.
  3. #3 Re: Whinny noise from Alternator side??
    Quote Originally Posted by boosting98 View Post
    Thanks for the response. Perhaps, I should replace the pulley on the alternator belt tensioner and see if this noise goes away...the two pulleys are so close together...I would hate to spend $250.00 on the alternator
    RED- 4 Door Sedan
  4. #4 Re: Whinny noise from Alternator side??
    ^that alternator belt tensior is most likely your problem. should make like a hissing sound.
  5. #5 Re: Whinny noise from Alternator side??
    I will definitely give it a world...the sound is not so much grinding but "pitchy" --high and low squeals.
    RED- 4 Door Sedan
  6. #6 Re: Whinny noise from Alternator side??
    Quote Originally Posted by Burgundyman View Post
    UPDATE....When I removed the tension pulley I noticed a bit of play and a rattling noise when rotating by hand. I replaced the tension pulley (GM 24506756, $38.16).Noise is gone. I have not taken it on a test drive yet but I suspect that this should remedy the problem. I checked the alternator pulley for any play, while the belt was off and did not notice anything unusual. There was a slight squeak but is disappeared when I rotated it quickly by hand.
    RED- 4 Door Sedan
  7. #7 Re: Whinny noise from Alternator side??
    very nice. u should notice the supercharger whine alittle more than usual 2!
  8. #8 Re: Whinny noise from Alternator side??
    If it doesn't fix it you might try power steering...I know it isn't on top but it is worth a shot at least checking to see if that is where it might be coming from
  9. #9 Re: Whinny noise from Alternator side??
    I did check the power steering pump pulley and also the fluid level. Everything seemed fine. The new pulley from GM is metal and much more sturdy than the plastic housing pulley that I removed today. GM must have figured it was flawed and improved on the design.
    RED- 4 Door Sedan
  10. #10 Re: Whinny noise from Alternator side??
    Final Report...Problem cured.
    RED- 4 Door Sedan
  11. #11 Re: Whinny noise from Alternator side??
    SE Level Member KevSorbo's Avatar
    Socal
    I too have the whining sound coming from my alt. side. I figured it was the Tension pulleys so I got a new one from Autozone. I also replaced 3 pulleys and my S/C belt and all them came off easily.
    However when I tried to take off the Tension Pulley from the Accessory side, it wouldn't budge. I didn't want to force it in fear of breaking it off. Does it come off with a simple 13mm bolt like the others? I'm only asking to make sure I don't damage it.
    Thanks in advance!
  12. #12 Re: Whinny noise from Alternator side??
    ok....noise is back with a vengeance...It is definitely the alternator...It appears to be the rear bearings...I am going to replace it with an OEM from a buddy who works at GM.
    RED- 4 Door Sedan
  13. #13 Re: Whinny noise from Alternator side??
    Jan 2009
    New castle, pa
    Mine did the same thing! At first it was only there when the car got hot but after a while it started doing it constantly. I took the belt off and the alternator definately felt like the bearings where out.
  14. #14 Re: Whinny noise from Alternator side??
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    My mino used to do that, id go thru a 140amp every 6-10 months. I changed belts and didnt have a problem again.
  1. Alternator output
    By Dohner in forum Audio, Security & Visual Electronics
    Last Post: 03-31-2009, 11:25 PM
  2. alternator
    By Slueth66 in forum General Tech Discussion
    Last Post: 01-29-2009, 10:05 AM
  3. is it my alternator?
    By boosting98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2009, 05:38 PM
  4. Alternator ????????
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 10-27-2008, 11:01 PM
