Thread: vacuum pressure problem
Results 1 to 4 of 4
  1. #1 vacuum pressure problem
    SE Level Member comongoose's Avatar
    Jan 2009
    Gainesville, Fl
    Well I just recently got done putting the new motor in and now the car idles really rough. The map sensor jumps from 35-65 KPa. I noticed that my brakes also felt as though there was no brake booster connected to them. Anyways I found that when I caped the nipple on the supercharger that goes to the vacuum line to the brake booster, the car's idle smoothes out and map reading stabilizes around 45 Kpa. The vacuum line has no leak and the attachment lets air pass. I am thinking it has something to do with the brake booster ruining my vacuum pressure. Do I need a new one, or am I forgetting another vacuum line or something. If it needs to be replaced, is there a rebuild kit for it? BTW I was also expecting my supercharger to be loud enough for me to hear it. When I rev it I barley hear it or sometimes it is nonexistent. ON youtube there is some kid with a stock series 3 and he puts on K&N air filter and that thing whines so loud. I have full headers, HAI, 1.9 rockers and it sounds nothing like his. Why can't I hear her whine?
    -1999 GTP...Work in Progress! L26 bottom end, K&N HAI, ZZP MPS 3.5" pulley, headers, custom intake, 180 therm., 1.9 rockers
    -1996 Acura TL
    -1995 Trans Am...SOM beast...RIP.
  2. #2 Re: vacuum pressure problem
    Quote Originally Posted by comongoose View Post
    Just for your sake...pull off the blower and see if the gasket moved or something...worth a shot...sounds like something underneath isn't quite sealing idk...
  3. #3 Re: vacuum pressure problem
    take a picture. the thing on the top of the blower should have all the lines filled. here, look at mine:
    there is one that goes to the BBV, one that goes to the brake booster, and another that im not sure where it goes to, but i can check it a little later if need be.
  4. #4 Re: vacuum pressure problem
    Barksdale AFB, LA
    The third one goes to your HVAC controls.
    If you cap the booster line and the issue goes away, your problem will be somewhere in that direction. Might want to see about getting another brake booster hose. They're cheap. Yours may have a small split.
    2009 Subaru Impreza WRX STI
  1. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  2. brake booster vacuum problem
    By comongoose in forum Brakes/Suspension/Chassis
    Last Post: 03-20-2009, 12:46 PM
  3. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  4. Vacuum hose
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2008, 07:01 AM
  5. vacuum leak
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2008, 08:22 AM
