Thread: Porting a blower housing to accomidate N*
Results 1 to 8 of 8
  1. #1 Porting a blower housing to accomidate N*
    Feb 2008
    I'm going to attempt to bore my blower housing to accept the 75MM bore of the N* TB, but it looks as if the bore may have to go in at an angle, rather than straight on. Does anyone have any pointers or instructions for me?
  2. #2 Re: Porting a blower housing to accomidate N*
    TDCRacing
    Guest
    Get a crosshatch bit or a cutting type. Don't wast you're money on a carbid bit one. You get get a lot of use out of a regular one.
    It's not hard, Just take you're time. It really is not hard.
  3. #3 Re: Porting a blower housing to accomidate N*
    Bastard Reptile's Avatar
    Kansas City, MO
    #1, get you a bit specifically for cutting aluminum. They will have these huge gnarly looking teeth, but they clean out nice when you're going to town. The smaller type that are used for steel will gum up when the aluminum gets soft.
    Make your marks on the outside, and cut the hole to match your TB, then taper it down into the intake side of the supercharger. You won't be able to make it that big all the way down, but what you are looking for here is a smooth transition from throttle body to supercharger.
  4. #4 Re: Porting a blower housing to accomidate N*
    Feb 2008
    I have a bit designed for cutting aluminum, but it is just cylindrical. It doesn't have a taper to it. Should I get one like the ones used for P&Ping aluminum heads, with the taper?
  5. #5 Re: Porting a blower housing to accomidate N*
    TDCRacing
    Guest
    What you have will work fine. You make the taper. Not the bit.
  6. #6 Re: Porting a blower housing to accomidate N*
    Feb 2008
    Sweet! Thanks for the help, guys!
  7. #7 Re: Porting a blower housing to accomidate N*
    TDCRacing
    Guest
    Not a problem Dan!
  8. #8 Re: Porting a blower housing to accomidate N*
    Kansas City, MO
    Quote Originally Posted by DanGTP View Post
    Like parker said, you can do it with just the cylindrical shape, however, a snub nosed bit does make tapering things much easier, and it doesn't gouge the aluminum as bad if you slip.
  1. TB porting questions..
    By Bio248 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2012, 04:20 PM
  2. Porting TB & Intake
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-04-2009, 10:41 AM
  3. Porting parts
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2009, 04:22 PM
  4. question on porting
    By HuffinV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 01:45 AM
  5. porting
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2008, 05:29 PM
