Thread: Engine Quits After 30-45 Minutes
Results 1 to 6 of 6
  1. #1 Engine Quits After 30-45 Minutes
    SE Level Member DanGale's Avatar
    Oregon
    Hi,
    I have a 1997 Grand Prix GTP 3.8L
    Recently My Car Will idle and/or drive for about 30-45 minutes then the tachometer drops to 0 the car will still drive for about 5-10 minutes then it dies.
    I cannot restart it immediatley. The first time this happened i tried disconnecting the battery cables and it seemed to reset itself and would start again in about 5 minutes.
    But now a week later it takes 30 minutes to sometimes 4 hours before it will start up again.
    I have done the following:
    Changed Plugs And Wires. I use Erodium Plugs And Wires From Pontiac.
    The wires are not crossed.
    I have purchased a new battery thinking the battery may have something to do with it as it was weak.
    I took it to the pontiac dealership on Friday 3/13/09 and paid them 125.00 for a diagnostic test. They said the #3 Cyl is misfiring.
    And they cannot go any further with the test.
    What a rip off.
    I thought maybe a friends 4 year old may have put something in my gas tank as I have dealt with this in the past with a 1967 Camaro and found a smooshed ping pong ball in the gas tank and everytime I gave it gas the car would fall on its face and die as it was being starved of fuel.
    This is not the case.
    I was wondering if anyone knows how to fix this issue. Before I start dumping money into fuel Pump, Fuel Filter and a new brain as they are a expensive fix.
    This sucks as I live 45 min from my job and I end up parking 4 blocks away as the car dies.
    Any Ideas Would Be Great.
    Thanks
  2. #2 Re: Engine Quits After 30-45 Minutes
    Isanti, MN
    crank shaft sensor
  3. #3 Re: Engine Quits After 30-45 Minutes
    Nov 2008
    norman oklahoma
    i agree
  4. #4 Re: Engine Quits After 30-45 Minutes
    Donating Users kfish's Avatar
    Ohio
    ya its the cps, look around there is a writeup somewhere around here on how to change it.
  5. #5 Re: Engine Quits After 30-45 Minutes
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I agree, i had the same problem when I bought mine.
  6. #6 Re: Engine Quits After 30-45 Minutes
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    cps x1000, ive had 2 go on me. dealership fails for not figuring this out
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  1. Replies: 84
    Last Post: 09-09-2015, 08:10 PM
  2. Runs 5 minutes...Stalls...Changed everything
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2009, 02:47 PM
