Thread: Blinking service engine soon light.
Results 1 to 9 of 9
  1. #1 Blinking service engine soon light.
    Oregon
    I have a 1999 Grand Prix with a 3.8l Supercharged. Today I was driving and the service engine soon light came on and it was blinking. I have had it come on before but it was not blinking. It drove very well at higher speers ( I was on the expressway, so 65-75 mhp) but in stop and go traffic it was chugging. It as not making any weird noises or anything, but it just seemed like it was heistating a little. Also when I tryed to go from lower speeds to higher speeds, the supercharger was making a rattly sound. Keep in mind this is a new supercharger that I replaced about a year ago, so i dont think that the superchager is the issue. Any advise?
  2. #2 Re: Blinking service engine soon light.
    Dec 2008
    Canada
    Scan it for a code, then post the code if you need further help?
  3. #3 Re: Blinking service engine soon light.
    Barksdale AFB, LA
    A blinking CEL means there is most likely a misfire condition and unburnt fuel is being dumped into your exhaust (which is bad for your catalytic converter). Need to get it checked ASAP.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Blinking service engine soon light.
    I live here. UR LOSN's Avatar
    Rockford, IL
    ^^^^^ thats what I was thinking.......
    scan it first from any autoparts store for free......
  5. #5 Re: Blinking service engine soon light.
    Donating Users
    Plainfield, IL
    had the same exact prob ended up being a cracked plug i bet its that or check your coils
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  6. #6 Re: Blinking service engine soon light.
    Nov 2008
    Chicago
    Will it flash if there is KR?
  7. #7 Re: Blinking service engine soon light.
    Barksdale AFB, LA
    Quote Originally Posted by FuglyGTP View Post
    No.
  8. #8 Re: Blinking service engine soon light.
    Oregon
    I am not sure what KR is, sorry..... before this happened my SES light was on and it scanned that is was the MAF sensor, I have not replaced it yet.....
  9. #9 Re: Blinking service engine soon light.
    SE Level Member schreurs1's Avatar
    Dec 2008
    sioux falls, sd
    flashing check engine light is a P0300, random multiple misfire. fuel is unburnt and going into the exhaust stream which superheats the exhaust stream thus melting the cat converter in no time. if its hesitating and seems like its struggling to accelerate like it used to, the cat is melted and plugged shut. easiest way to tell is drill a pinhole right before the cat. if its blowing a lot of air out that little hole, its plugged. if it is not plugged, get it fixed asap before it melts the converter.
  1. Service engine soon light
    By the955iman in forum General Tech Discussion
    Last Post: 02-15-2009, 01:21 PM
  2. check engine light
    By kiljoy06 in forum General Tech Discussion
    Last Post: 01-11-2009, 07:27 AM
  3. Engine light came on what to do?
    By jasonball in forum General Tech Discussion
    Last Post: 12-03-2008, 03:44 PM
  4. *ERROR CODE INSIDE* Installed new PCM - Service engine light is on
    By Freebeer187 in forum General Tech Discussion
    Last Post: 11-23-2008, 07:05 PM
  5. Service Engine??
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 11:55 AM
