Thread: GAS
Results 1 to 13 of 13
  1. #1 GAS
    illinois
    Okay i just brought my 1997 grand prix supercharged about a week ago. Already ive had a problem which was the crank shaft but other than that so far so good. This car has 160,000 miles on it and im the 3rd owner and it seems like it was very well tooken care of. i paid $2700 for the car. Is there anything i should be aware of and also on the dash it says unleaded and on the gas door it says unleaded but the book says premi so what should i use? I really dont know much about cars but i am learnin so bare with me
  2. #2 Re: GAS
    GTP Level Member Scimmia's Avatar
    QCA, IA
    You should use premium, which is unleaded. Unleaded doesn't mean regular, it just means it doesn't have lead in it, which means virtually all pump gas these days.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: GAS
    illinois
    Ok thank you so what should i beaware of with these cars?
  4. #4 Re: GAS
    Nov 2008
    Searcy,Arkansas
    One thing I would check....is the SC oil. I bought my 07 used with rmm like 20K or 30K miles and the SC oil was DIRTY! Alot of people truly dont know it has oil! IMO that would be something I would check/change. Then the basic Spark plugs and so forth.
  5. #5 Re: GAS
    illinois
    Im sorry but what is sc oil...?
  6. #6 Re: GAS
    TDCRacing
    Guest
    Supercharger oil. If you stand in front of you're car. Lift the hood. Look on the snout (close to where the belt is located) and you will see a allen head bolt. Unscrew that and the oil level should be near the top of the fill hole. About a 1/4 inch from the fill hole.
  7. #7 Re: GAS
    TDCRacing
    Guest
    Oh. And to drain the oil you have to get a syringe and suck it all out. Then replace it with GM supercharger oil. You can get that from you're dealer.
  8. #8 Re: GAS
    Nov 2008
    Searcy,Arkansas
    Hope this helps.
  9. #9 Re: GAS
    Ohio
    ^ They said it exactly. Also beware that that sh*t stinks. Just a heads up! If its brown and smells bad change it!
    00 GTP demodded and forsale
  10. #10 Re: GAS
    Aug 2008
    Long Island, New York
    Quote Originally Posted by speedemongtp View Post
    that it does...
  11. #11 Re: GAS
    illinois
    Thank u guys so much
  12. #12 Re: GAS
    Ohio
    Another way to remove it if you have it available to you is a hand held vacuum pump with a catch can. If you wanna do it that way instead and don't have one you can rent one at your local auto parts store. Another way as well is a turkey baster with a tube on it. I even saw a writeup using the sprayer from a windex bottle. Just a few other options for you.
  13. #13 Re: GAS
    Charles City, IA
    I always use the spray bottle top and it works good.
    SMGPFC Two Nipple General
gas
