Thread: supercharger noise at idle
Results 1 to 12 of 12
slippyskippy supercharger noise at idle 01-07-2009, 07:46 AM
BADAZGTP Re: supercharger noise at idle 01-07-2009, 07:50 AM
Guest Re: supercharger noise at idle 01-07-2009, 08:06 AM
SyntheticShield Re: supercharger noise at idle 01-07-2009, 11:16 AM
josh Re: supercharger noise at idle 01-07-2009, 07:01 PM
Reptile Re: supercharger noise at idle 01-08-2009, 12:42 PM
slippyskippy Re: supercharger noise at idle 01-12-2009, 04:27 PM
BADAZGTP Re: supercharger noise at idle 01-08-2009, 02:28 PM
Bubweiser21 Re: supercharger noise at idle 03-09-2009, 06:36 PM
BADAZGTP Re: supercharger noise at idle 03-09-2009, 07:11 PM
Bubweiser21 Re: supercharger noise at idle 03-10-2009, 05:11 PM
BADAZGTP Re: supercharger noise at idle 03-10-2009, 08:14 PM
  1. #1 supercharger noise at idle
    Jan 2009
    St. Augustine, FL
    Helo all!
    I now have 106,000 on a 2000 GTP, original owner. Sucked out the SC oil at 100,000 and put fresh in - filled to threads at cold condition.
    What I have now is a whirring noise at cold start up that continues when you manually increase the idle. The noise went away when hot and back at idle again. I've read the thread about rattling noises and this doesn't seem to be this - well at least not yet. The noise is loud enough to get your attention. My wife says she "kinda" heard this AFTER driving it yesterday.
    Any suggestions? Add an additive? What could be used instead of the GM little expensive bottle of SC oil? Would replacement of what bearings be good to do at this mileage and age? Email me if you like - I'm the kinda guy that wants to fix this ASAP.
    Thanks alot,
    Stan
  2. #2 Re: supercharger noise at idle
    Apr 2008
    Chillin at the Beach , VA
    First off, welcome to the forum. Happy to have you here. You need to post this up in the correct section to get a good and quick response. Put in the L67 engine section.
  3. #3 Re: supercharger noise at idle
    TDCRacing
    Guest
    Welcome to the community!
  4. #4 Re: supercharger noise at idle
    Oklahoma
    Welcome to the community. Moved this to the correct area.
  5. #5 Re: supercharger noise at idle
    Jan 2009
    Grand Rapids, MI
    Are you sure the noise is coming from the actuall SC or is it coming from your air intake box? My car makes a simaliar noise when its cold but it's from my K&N filter. Your SC coupler is what usually makes the rattling sound. If it were me I would probably replace the coupler and rebuild the snout. I'm rebuilding mine this winter and my blower has less than 90k on it.
    XP~GEN V~SSIC~2.8~HEADERS~P&P HEADS~78mm TB~SLP LOUDMOUTH
    318 whp, pump 92 octane, 18" wheels
    Before Gen V
  6. #6 Re: supercharger noise at idle
    Bastard Reptile's Avatar
    Kansas City, MO
    The supercharger will rattle if any of the bearings are worn, or if the coupler is going bad.
    A whine usually leads to a power steering pump, or maybe one of the idler/tensioner pulleys also.
    Start by taking off the supercharger belt, start the car and see if the whine goes away. If it does, then check all of the other pulleys on the supercharger drive with the engine off.
    Check for play in them, see if they "catch" because of a bad bearing.
    I've even seen where the belt whines.....it sounds weird I know, but it happens.
  7. #7 Re: supercharger noise at idle
    Jan 2009
    St. Augustine, FL
    Thanks for the insight and information. I changed the SC fluid and haven't heard the noise since. The belt is a little worn, and there's alot of "belt powder" on the cooling over flow tank and in the front of the engine. GM replaced a valve cover gasket on a recall, and until this happend I wasn't paying attention. Thanks again....
  8. #8 Re: supercharger noise at idle
    Apr 2008
    I believe goodyear belts will give a slight whine.
  9. #9 Re: supercharger noise at idle
    Feb 2009
    moundsville
    I have a similar issue but i couldnt find where to post it.. At idle my supercharger makes a rattling noise until u increase the rpms but at idle it resumes the sound.. Where can i find a rebuild kit? How much? My local auto parts stores are saying 1000 for a rebuilt s/c and they dont offer a rebuild kit.. My car has 170k
  10. #10 Re: supercharger noise at idle
    Apr 2008
    Just sounds like your S/C coupler is worn out. ZZP has them for like 15 bucks.
  11. #11 Re: supercharger noise at idle
    Feb 2009
    moundsville
    zzp?
  12. #12 Re: supercharger noise at idle
    Apr 2008
    zzperformance.com. Sorry.
  1. Supercharger noise, rattle HELP!
    By Mvfootball1 in forum General Tech Discussion
    Last Post: 08-26-2010, 04:49 PM
  2. Almost rough idle
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2009, 08:31 PM
  3. Stumble at idle
    By lowdeuce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2008, 10:26 PM
  4. Tapping noise at idle.
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2008, 09:43 AM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
