Thread: exhaust question
Results 1 to 20 of 28
  1. #1 exhaust question
    May 2008
    McHenry IL
    im sure its been said before.... but i want to delete my resinator and cat and u bend all at 1 time i dont think my GTP is going to see headers so i just want to be unique and run with my idea. can i get a piece of pipe drill out a hole for the 02 sensor and weld a bung in it or have a shop weld a bung on w.e. anyways my question is what would be the recomended sizes of length and inlet outlet size ? i want to get a raspy LOUD noise lmao thats the plan haha. will this work any tips? how much you think it would cost? do you really gain HP and better flow? thanks
  2. #2 Re: exhaust question
    id just get a 3" downpipe without a cat and then delete the resonator all at the same time.
  3. #3 Re: exhaust question
    SE Level Member 98GTP96792's Avatar
    Feb 2009
    Waianae. HI
    thats what i did. I have tog headers though. But i have a 3" downpipe, no cat, ubend delet and 3" tubing all the way back, I did it all at the same time too. watch my video and tell me what you think.
    http://video.cardomain.com/98GTP96792
  4. #4 Re: exhaust question
    May 2008
    McHenry IL
    THINKIN CHEAP! lol
  5. #5 Re: exhaust question
    Jersey
    x2 cat-less dp.
    16' wrx sti- stock
  6. #6 Re: exhaust question
    y would u want it raspy?
  7. #7 Re: exhaust question
    St. Louis Mo.
    Quote Originally Posted by boosting98 View Post
    Come on, look who is asking.........
    Just leave the cat on, have the muffler shop tack in a 2.5" pipe from the end of the cat to the bend at the gas tank. And have them drop in an O2 Bung for the sensor. Should only run about $100-150 bucks. Good luck with the droan you are gonna have in your car now too.
    James Shafer
    St. Louis MO
  8. #8 Re: exhaust question
    for the power gain youre going to get from the cat and resonator delete it really doesnt justify how nasty it is going to sound.
  9. #9 Re: exhaust question
    Jersey
    that poor gtp
    16' wrx sti- stock
  10. #10 Re: exhaust question
    May 2008
    McHenry IL
    ok ill leave it alone haha
  11. #11 Re: exhaust question
    if u want to do anything. and be cheap about it. just delete your ubend!
  12. #12 Re: exhaust question
    I'd say 3" DP (cat in or out its up to you)
    Have the shop make a U-Bend Delete...mine did it for $50...and I'd leave the res. Taking out the cat/u-bend and installing a DP will more than make enough sound Taking out the resonator makes it sound like epic dog s**t
  13. #13 Re: exhaust question
    May 2008
    McHenry IL
    yeah i thinkk imma delete the U and ressy good idea guys?
  14. #14 Re: exhaust question
    keep the res.
  15. #15 Re: exhaust question
    Nov 2008
    Cedar Rapids, IA
    I understand where you're coming from but really, there is a reason the resonator is in there and trust all of us, you won't like your resulting exhaust. There are plenty of suggestions above for getting a louder exhaust while still maintaining sanity
  16. #16 Re: exhaust question
    May 2008
    McHenry IL
    lol ok =] lol what if i replace the ressy with a cherry bomb? lol
  17. #17 Re: exhaust question
  18. #18 Re: exhaust question
    SE Level Member 04compggtp's Avatar
    Feb 2009
    new york
    What performance upgrade do you get from a glasspack instead of the fact resonator? what kind of sound difference? is it a 3" or 2.5?
    Thrasher cai, s&b 9",zzp stainless power log, zzp 3" cated dp, :180*t stat, autolite 104's, overkill pcm,: thrasher 3.4 modular pulley,F&R drilled/slotted rotors. 245/45/18 Fierce on Casino's
  19. #19 Re: exhaust question
    it sounds different. i run a 2.5" because there is no reason to run a 3" exhaust on an m90 car. it sounds more throaty and doesnt make such a nasty exhaust note up top, but it still sounds like garbage.
    i have stock mufflers, by the way.
  20. #20 Re: exhaust question
    Feb 2009
    new york
    will at overkill suggested that I get a 3" cat back to go with the rest of my mods, then pcm modification. I have the plog and 3" dp with cat. I am not sure if I want the 3" cat back. I will be sending out for the pcm in a couple of weeks, because I do not drive the car in the winter, so not in a hurry. any suggestions about the cat back? I did not think it was necessary.
  1. Exhaust Question
    By stkks in forum General Tech Discussion
    Last Post: 10-28-2008, 06:42 PM
  2. Exhaust Question.
    By Dboy23 in forum Visual/Body Modifications
    Last Post: 10-16-2008, 10:07 PM
  3. exhaust question
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-25-2008, 01:47 PM
  4. exhaust question
    By kingd44 in forum Off Topic Discussion
    Last Post: 03-01-2008, 11:57 PM
  5. exhaust question
    By JetBlackGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2008, 10:02 PM
