Thread: Random CEL light
Results 1 to 6 of 6
  1. #1 Random CEL light
    Aug 2012
    Arkansas
    2000 Grand Prix GTP 184xxx miles
    Guys I need some help here!
    When the car is just idling, whether Im sitting in the driveway or at a light there is no CEL, when i accelerate or push on the gas pedal after about 30 seconds the CL starts flashing. When i go back to idle after a minute or two the light goes off. Checked it with the scanner and it shows misfire in cylinder 3. Car doesn't run rough so i don't think it really is misfiring. My scanner wont do live data so I can't look at that but i have pulled the wire and the plug and it is firing like it supposed to. I have swapped and replaced plugs, wires, coil and injector and it is still doing the same thing. Thought it might be a manifold gasket but it doesnt make sense that it would go away at idle.
    Any ideas?
  2. #2 Re: Random CEL light
    either you need a tune up, or the cats clogged.
  3. #3 Re: Random CEL light
    Aug 2012
    Arkansas
    Well I've done plugs and wires and replaced that coil and that injector on #3 so I guess I'll check the cat. Thanks
  4. #4 Re: Random CEL light
    if its been feeling down on power its the cat for sure. if you got a temp laser you can drive it and then see the pre and post cat pipe temps. if post is way cooler the cats bad.
    or you can drive it late at night and drive it some what hard, not full on beating it tho cause the flashing cel means catastrophic event is happening. then pull over and look under the cat to see if the cat and down pipe are glowing red.
  5. #5 Re: Random CEL light
    St. Louis
    Here's some additional reading on your issue--> Cylinder 3 misfire Tried everything I can think of
    Also, what did the electrode look like on the plug that you originally pulled out of #3? Gap still open? I also assume you run at least 91 octane fuel that the S/C cars require.
  6. #6 Re: Random CEL light
    Aug 2012
    Arkansas
    Plugs all pretty much looked the same when I did the TU. 91 or 93
  1. Random ABS light, no codes, all speed sensors reporting.
    By buickman104 in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2017, 09:09 AM
  2. After transmission swap no Head Unit Display and random ABS light
    By buickman104 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2016, 11:17 AM
  3. '08 GXP Random Air Bag light
    By HeavyChevy in forum General Grand Prix Discussion
    Last Post: 07-28-2015, 09:40 PM
  4. Random air bag light
    By stealthee in forum 04+ Specifics
    Last Post: 10-18-2011, 05:25 AM
  5. Security light comes on at random
    By Andrew_99GTP in forum Off Topic Discussion
    Last Post: 05-19-2008, 09:44 PM
