Thread: 2005 GTP full throttle battery drop
Results 1 to 5 of 5
  1. #1 2005 GTP full throttle battery drop
    Sep 2022
    Saskatchewan
    I have a 2005 grand prix GTP and when I punch the throttle to pass or do a speed pass the charging system failure light comes on and my battery voltage drops from 14.2 to below 9 and the car loses power once I let off and go back to driving normal the battery charges fine again boost gauge only gets to about three quarters of the gauge as well on the DIC I believe it used to peg the gauge when punching it. Please help I love this car but it's annoying. Also with car on accessory the battery sits at 12.29 volts
  2. #2 Re: 2005 GTP full throttle battery drop
    Apr 2014
    commerce twp,mi
    couple of things im thinkin:
    clean battery terminals and grounds. check alt terminals. have battery load tested and test the alternator.
    08 grand prix NA3800
  3. #3 Re: 2005 GTP full throttle battery drop
    Sep 2022
    Saskatchewan
    Cables are clean 0 corrosion on them also every once in a while my rpm,fuel,temp,boost gauge quit working for like 5 mins then after restarting the car it well work again my obd 2 port also quits working. During. This the lights slightly dim
  4. #4 Re: 2005 GTP full throttle battery drop
    Sep 2022
    Saskatchewan
    Cables seem good I'll check grounds battery has never given me problems.. also every once in a while my rpm,fuel,temp,boost gauges die and my obd2 port quits working as well until I restart the car.
  5. #5 Re: 2005 GTP full throttle battery drop
    Sep 2022
    Saskatchewan
    Batteries good cables are good also having a problem where the rpm,temp,boost,and obd2 port quit working for about 5-10 minutes with slight light dimming then after restarting everything works again
  1. 04 gtp misfiring at 3/4 to full throttle
    By rileychris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2021, 11:09 AM
  2. Stutter under full throttle?
    By Stevenhendrixjr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2013, 05:18 PM
  3. Full Throttle Hiccup
    By BigKev2403 in forum General Grand Prix Discussion
    Last Post: 05-09-2013, 07:29 AM
  4. Hitch when under full throttle
    By rvnwlf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-20-2012, 08:22 PM
  5. KR under full throttle
    By Twist in forum General Tech Discussion
    Last Post: 04-16-2012, 12:55 AM
