Thread: Boost curve
Results 1 to 8 of 8
  1. #1 Boost curve
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    Does anyone have a data log that they have a cam and ported heads? Im curious if your boost will slowly creep higher with rpm or if it stays flat up to redline.
  2. #2 Re: Boost curve
    boost will build with rpm's. you wont see max psi till red line. or your shift points.
  3. #3 Re: Boost curve
    Kemmerer, Wyoming
    I looked at a scan from 2017 and my boost level hits close to max pretty quick. the car is gone now and I don't remember what mods I had on at that point.
    but I do know that I had ported heads and an XP cam at that point.
  4. #4 Re: Boost curve
    Sep 2018
    NC
    I only ask because in theory the supercharge should be moving the same amount of air regardless of speed. So for the boost to increase with rpm I can only imagine it is because of a restriction in flow of the heads or exhaust. Unless im missing something...
  5. #5 Re: Boost curve
    the blower is rpm dependent. more rpm's the faster the blower spins, thus more boost with more rpm.
  6. #6 Re: Boost curve
    ive got a paxton on my 5th gen camaro. at 6300 it makes 6.7 psi. at 6700 it makes 7.5. seen this on my scans with hpt.
  7. #7 Re: Boost curve
    Kemmerer, Wyoming
    mine was with an HP Tuner scanner as well. your paxton doesn't make peak boost like an Eaton M90 because it's centrifugal. roots/pd blowers hit close to max boost much faster than centrifugal.
  8. #8 Re: Boost curve
    its still instant power off the line. belt driven turbo really.
  1. Boost gauge showing maximum boost when not touching gas pedal
    By NotEnoughGPs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-09-2017, 10:59 PM
  2. 3.4 DOHC Torque Curve
    By pshojo in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-08-2017, 01:38 PM
  3. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  4. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
