Thread: 180tstat causing issues?
Results 1 to 4 of 4
  1. #1 180tstat causing issues?
    Jun 2022
    San Diego
    Hello everyone...noob back again with another dummy question.. sorry about all the posts I just want to get my new gtp road worthy and have some fun for once... anyways I just put in the 180tstat as I've read it's a good thing to do for these cars...but further digging I learned that it doesn't do much unless I get a tune to have the fans kick on at 180 as well? So is this kinda a waste until I do get the tune? And more importantly can it cause any issues? Went to AutoZone to use there OBD2 to verify my CEL causes, and something came back regarding a thermostat? Don't see why that would happen unless using the 180 is throwing things off?
  2. #2 Re: 180tstat causing issues?
    St. Louis
    I'd stick with the stock thermostat as you are correct, a lower temp one will not trigger the fans unless you are tuned to do so.
    If you have a CEL code always post it here so we can help w/o trying to guess what it is. Will get you more accurate answers.
  3. #3 Re: 180tstat causing issues?
    Jun 2022
    San Diego
    Ok I will order an OEM 195tstat and put that in...but until then will the 180 cause any of the issues I'm having? High trans temp/cylinder 1 misfire And yes the CEL code is p0301 should I start another thread?
  4. #4 Re: 180tstat causing issues?
    GT Level Member 97gtp01gt99gt's Avatar
    Sep 2018
    Saint Louis
    Cylinder 1 misfire plug coil or wire
  1. Is there a way to tell what's causing kr?
    By Lcsowheeler in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2015, 11:54 AM
  2. New head unit causing issues?
    By SuzukiGS750EZ in forum Audio, Security & Visual Electronics
    Last Post: 06-01-2014, 08:43 PM
  3. how to tell if u have a 180tstat
    By t wizzle17 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2013, 05:58 PM
  4. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  5. What's causing this?
    By BwolfGT in forum General Tech Discussion
    Last Post: 10-02-2009, 04:57 PM
