Thread: Smelling coolant
Results 1 to 15 of 15
  1. #1 Re: Smelling coolant
    St. Louis
    Besides the elbows, I'd also check both rad hoses and the heater hoses if they are older. Only takes a little seep to cause a smell. Also give the radiator a look and see if there is a trail of dried up coolant on the side tanks or on the fins.
  2. #2 Re: Smelling coolant
    Donating Users GT2000's Avatar
    Oct 2017
    Central PA
    Yes, the radiator, especially the cap. I got a Chevy venture for free that I was told had a bad head gasket. It ended up just being the cap was worn out, after I replaced that, the coolant level didn't move.
  3. #3 Re: Smelling coolant
    SE Level Member LouF's Avatar
    Oct 2011
    Ohio
    Thanks, all. All these things do look OK (radiator tanks are a bit difficult to thoroughly see). Maybe it's just me.
    Glad to hear gaskets aren't a resounding "yes".
    I meant to mention the radiator hoses are fairly new. I opted not to touch the plastic elbow at the front of the s/c when I saw that it looks like it doesn't come out short of taking off the s/c (no coolant traces in the area as of now).
    I will try and follow up with this post, but I'm going to put it off as long as possible.
    2005 Grand Prix GTP
  4. #4 Re: Smelling coolant
    Nov 2015
    Ontario
    I sort of had the same problem. My car would overheat thru the top of the overflow bottle and since I changed the rad cap it has been fine....
  1. Smelling gas while idling after l67 swap
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 06-03-2013, 10:37 PM
  2. Smelling gas..
    By CapnBreakAlot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2013, 07:49 AM
  3. Keep smelling gas in my car
    By sammie in forum General Tech Discussion
    Last Post: 04-14-2012, 12:34 PM
  4. smelling fuel.
    By salty711 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-29-2011, 09:13 AM
  5. Smelling antifreeze
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 11:06 PM
