Thread: Power Steering Fluid In The Brake Reservoir
Results 1 to 11 of 11
  1. #1 Re: Power Steering Fluid In The Brake Reservoir
    HUDSON
    To be safe, you will need to change any part that is made of rubber, or has rubber seals, (master cylinder, calipers/wheel cylinders, rubber hoses) No telling how the rubber brake parts are going to react to the power steering fluid over a long period of time. Brake parts rubber is different than other hydraulic systems that dont see the pressures or heat of an automobile brake system. Also the anit lock brake module will need to be flushed, and all the steel lines will need to be blown out and flushed to remove any residual PS fluid.
  2. #2 Re: Power Steering Fluid In The Brake Reservoir
    Nov 2020
    Missouri
    Got it, I appreciate the help.
  1. Where is the Power Steering Reservoir Cap???
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2012, 07:13 AM
  2. Power steering reservoir?
    By Dailordasailor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2012, 11:18 PM
  3. Wheres the power steering reservoir?
    By GTLGDP in forum General Tech Discussion
    Last Post: 04-17-2012, 06:36 AM
  4. HELP! Can't Find Power Steering Fluid Reservoir
    By mltyplx in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-04-2010, 07:05 PM
  5. What power steering fluid is best?
    By dl1027 in forum General Tech Discussion
    Last Post: 05-09-2010, 07:55 PM
