#21
Re: Misfire under load, increase with engine warmth and run time
Donating Users
09-06-2020
Yeah and that CRC maf cleaner is a little pricey, but it will literally last you forever...not literally. But yeah, there's enough to clean like 200 mafs. Only problem I have is grabbing the CRC when I should have grabbed brake cleaner because the brake cleaner was 10ft away and I'm lazy like that.
Top Swapped 01 Imp
#22
The maf looked fine and I didn't see any debris on the wires. No visible build up and should have run better if anything after blowing it and cleaning the intake with alcohol but continues decline. I have to wait for my next paycheck to get anything new.
#23
I dabbed the wires gently with alcohol and q tip but seriously they looked fine. There's a pic below. No change so I drove with maf and EGR disconnected for about 20 minutes and no change. On another note when checking the lower vac tube I saw this nipple not connected to anything. No hose anywhere to connect it to. Please consult pics below and provide any insight if you see anything amiss. Thanks
Microsoft services
#24
I'd trace that one back, and unless it's different than the l67, there is also a hose missing off the vacuum tree on top of the supercharger in picture # 3.
#25
That's what it looks like. How the **** do I find out what's missing? I don't see anything else missing a hose. Has to be two sides.
#26
09-09-2020
Nothing is missing in your pictures. Pull up a vacuum diagram of your engine and you'll better understand what you are looking at.
The boost bypass solenoid would originally have a piece of foam over that open nipple. That's how it vents to work the bypass valve.
The manifold on top of the SC is capped because it's not needed. Back in the early years of the H/C/G body some of the HVAC doors etc worked via vacuum and had a connection there. Once GM went with only servo actuators that connection point was not necessary.
09-09-2020
I don't think your problem is map/maf related.
There are a lot of people on the forum who are well versed with solving these kinds of issues. Oddly as many give you advice, you are either not able to follow it financially or would prefer to spend a lot of time going in a different direction. It's a bit frustrating trying to help you out on this issue.
When you unplug a sensor on a running engine it's about the same as you closing your eyes when you are running in the woods. You'll stumble and try to catch your balance, as will the engine. By unhooking sensors you have to expect that the pcm is missing an input that it's used to seeing. So it'll compensate the best it can.
Free for you to check:
Pull the spark plugs, do any look significantly different than the others?
Look at your spark plug wires, do any have a mark on them where they are laying on/touching metal?
Start motor at night and mist the engine with water, see any sparks jumping around?
There's no need to insult me for being poor and I've followed advice given here and elsewhere , hence unplugging the sensors to note any change. I've done all cheap repairs suggested including some that were actually needed.
As reported above, according to the cylinder balance test that I did as suggested above from the troubleshooting guide, all my wires, plugs, injectors, and coils are good.
If you disagree with that guide, please tell me why. The plugs and wires are like six months old. That's why I'm looking to move on to a next step. Thanks
#29
![Quote](https://www.grandprixforums.com/images/redfox/misc/quote_icon.png)
BillBoost37
My bad on that one. mine has the vacuum line at that 3rd port , and I couldn't confirm for sure if it still applied on the L32's until well after I posted that.
**Those responsible have been sacked**
99 GTP:
ZZP FWI , ZZP 3" catted DP, Resonator delete,The occasional Poly bushing, ZZP front sway Bar, NGK TR6's, LED Headlights, 180* TStat, Anti- pogo washers ...This list seemed a lot longer before I started typing....
#30
I wonder if its as simple as a clogged cat. the symptoms are all there. sluggish, misfires, lack of power.
"Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#31
mguzzo
I've had that happen before too, but I don't recall it starting only when warmed up, as initially indicated. Maybe that was just circumstantial timing.
I still think it could be the MAF. if OP can get a replacement at the J/Y for around $7, that's about the price of a can of CRC (here anyway), so might as well swap it out & see. If it makes no difference, then they didn't need the cleaner anyway, and there will be a backup MAF for down the road.
99 GTP:
#32
I know its late, and I'm not (or ever was) expert, but the open-loop control jumps out to me on this.
I am now big on being very sure about vacuum leaks (because of age), but this is not how it reacts when it is vacuum. Two vacuum spots you may have missed - the tee beneath the S/C snorkel and the Evap solenoid near the EGR valve (it has an O-ring inside).
#33
"the tee beneath the S/C snorkel and the Evap solenoid near the EGR valve (it has an O-ring inside)."
Is there a pic I can take that someone can see if it's wrong? I got another unemployment check so it's time to fix this ****.
Updates:
1. It's not the maf, which ended up costing $20 and didn't change a thing. Anyone need an 04 maf?
2. I sprayed brake fluid around the sc and engine top according to a video and engine didn't try to stall.
3. It doesn't misfire under idle or even when revving at idle, but sometimes does backfire after rev.
4. Seems to only happen at the same time boost engages, but I don't know if that's a chicken or egg.
5. It's def not the cat, because there is none, just a pipe. Been like that for a long time before all these problems.
Thanks all.
#34
I only continued the hidden vacuum leak spots to complete the thought - I know vacuum leaks well now, and this doesn't sound like it (small = random intermittent misfires; large = shaking engine).
What about O2 sensors? (here's a video on open-closed loop closed loop control (starts at about 1/3 into the video)).
Understanding Open loop / Closed loop Basics - YouTube
#35
Wakingcrow
You should easily be able to tell if the rubber tee is bad - maybe try water at the joints. The Evap solenoid leak will be slight and only give more slight misfires - not like what you described. (And I certainly don't thing it needs PCM reprogramming).
2. Was that "engine top" for checking vacuum at the S/C bypass valve (solenoid) lines? This is located on top of the S/C toward the front of the engine.
3. That backfire sounds normal - I always get 2 misfires
4. (redundant) Check vacuum lines at that boost bypass valve. (I recall it being easy to mess those lines up.)
5. Maybe the O2s have gotten dirty. (for saving money and not remove-and-replace method of fixing, O2s supposedly can be cleaned with something like SeaFoam - of course, there are completely conflicting opinions).
#36
#37
It's running open loop because I had to disconnect the O2 sensor to avoid constant CO poisoning. I had to go to the hospital for hyperbaric O2 treatment, so I can't afford to run the O2 sensor. But from what I've read, only a bad O2 sensor can cause misfiring, not a disconnected one. At any rate, it doesn't have any problem heating up, as in the video, in fact according to the 'dumb gauge' gets hotter than it's supposed to already and I have to use a manual cooling fan switch when, driving city for more than 15 minutes. It started getting too hot about the same time that it started the constant misfiring so I think that's related. Cooling system seems fine, it's not using any coolant since I put in the "permanent head gasket sealer" which hopefully didn't clog anything else up except the petcock.
#38
The engine coolant temperature sensor?
#39
OK I borrowed a scanner and it's finally registering a specific cylinder, on two trips after reset. I captured all the freeze frame data in pics. Maybe there's a clue in there. But at least I have a specific cylinder to investigate now.
Microsoft services
#40
first off you need to reconnect the front O2 sensor. Without it the car is stuck in open loop. so you have no fuel trims and it's running like crap.
next you need to pull plug #3 (middle plug on front bank) and check its condition. Make sure the plug is not broken or bent. and the wire is in good shape and you have dielectric grease in the boot.
