Thread: Misfire under load, increase with engine warmth and run time
Results 1 to 20 of 66
  1. #1 Re: Misfire under load, increase with engine warmth and run time
    St. Louis
    There is also a specified MAF cleaning spray from CRC. I've used this on multiple cars and have never had an issue and it avoids touching the MAF wires with anything. Just spray it down, let it dry and reinstall.
  2. #2 Re: Misfire under load, increase with engine warmth and run time
    SE Level Member LouF's Avatar
    Oct 2011
    Ohio
    I know its late, and I'm not (or ever was) expert, but the open-loop control jumps out to me on this.
    I am now big on being very sure about vacuum leaks (because of age), but this is not how it reacts when it is vacuum. Two vacuum spots you may have missed - the tee beneath the S/C snorkel and the Evap solenoid near the EGR valve (it has an O-ring inside).
    2005 Grand Prix GTP
  1. 1999 Pontiac Grand Prix Misfire under load
    By Z28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-13-2015, 09:29 PM
  2. Misfire cylinder 2(actually 1) only under load
    By sseilmnop in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2015, 07:11 PM
  3. Heavy Isolated Misfire Under Load
    By Jomamma in forum General Tech Discussion
    Last Post: 11-15-2014, 02:20 AM
  4. 99 gtp misfire #1 under load /in boost Heelp!!
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2012, 12:50 AM
  5. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
