Thread: Can a bad MAP sensor cause the engine to run lean?
Results 1 to 14 of 14
  1. #1 Re: Can a bad MAP sensor cause the engine to run lean?
    This is going to sound odd, it's experience talking though.
    Look at your battery cables where they go into the ends by the battery and the other ends of them. Do you see the insulation pulled back slightly and greenish color instead of nice clean copper? If so.. consider replacing them.
    I chased P0171, replaced the egr tube (they crack at intake manifold), checked grounds in the harness etc etc etc. Then had guy who had been a GM mechanic for years tell me to replace the cables. Since I had done everything else, I did. Fixed the issue and when I opened up the insulation on the old ones I found a decent amount of corrosion which messes with the voltage of the vehicle.
  2. #2 Re: Can a bad MAP sensor cause the engine to run lean?
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    Thats something I will have to check in the morning. Come to think of it sometimes when sitting idle with the door open I notice my dome lights would fluctuate and I didnt think anything of it. Just thinking it was the voltage being regulated by the alternator.
  1. WTB Engine Temp sensor
    By chris99gtp in forum Wanted To Buy - Parts
    Last Post: 09-02-2015, 09:08 PM
  2. engine coolant temp sensor
    By Dee23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2015, 06:28 PM
  3. Check Engine Light - Lean
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 09-20-2011, 03:57 PM
  4. KR sensor,running lean and oil psi
    By izup69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2011, 09:40 PM
  5. Engine running lean
    By crd783 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2009, 01:26 AM
