it's actually probably easier to tune for the progressive kit because the maf tune you will be adjusting is also progressive, and injecting a fixed amount of water/methanol wont be steady, it will lean out some as the engine moves up the maf curve.
I went with the AEM kit and had good luck with it. Scott also used the AEM kit.
