Thread: Help me choose my meth
Results 1 to 14 of 14
  1. #1 Help me choose my meth
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Hi all,
    I have decided i want to add methanol injection to my regal. I just ordered an AEM wideband o2 for AFR tuing.
    The question is which meth kit to get. I am leaning towards Snow performance stage 1. Its the cheapest option, and i feel like the set meth amount will be easier to tune for . The stage 2.5 is harder to find, but it has a progressive controller that adds more meth as boost increases. Seems like that might make tuning hard, especially since any mods on these engines change boost.
    AEM has kits, but ive read their controllers can fail .
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: Help me choose my meth
    Sep 2014
    Richmond Virginia
    Also, for the wideband o2 , do i have to weld a new bung into the DP or can i re use one of the factory ones
  3. #3 Re: Help me choose my meth
    Apr 2015
    Columbus, OH
    I don't think it's really going to be easier or harder either way to tune. A tune is a tune. I put my wide band where the post-cat O2 sensor was. If you don't mind moving it the closer you can get to the front the better.
    Top Swapped 01 Imp
  4. #4 Re: Help me choose my meth
    Kemmerer, Wyoming
    it's actually probably easier to tune for the progressive kit because the maf tune you will be adjusting is also progressive, and injecting a fixed amount of water/methanol wont be steady, it will lean out some as the engine moves up the maf curve.
    I went with the AEM kit and had good luck with it. Scott also used the AEM kit.
  5. #5 Re: Help me choose my meth
    Sep 2014
    Richmond Virginia
    The Snow kit has braided lines and is about 75 dollars cheaper. Still a bit on the fence. Where did you guys put the nozzle ?
  6. #6 Re: Help me choose my meth
    Sep 2014
    Richmond Virginia
    I cheaped out and went with the snow kit, Its simpler to install and has some braided lines.
  7. #7 Re: Help me choose my meth
    i drilled and tapped the blower case right after the tb flange.
    follow the black tube thats zip tied to the shift cable near the intake tube. click the pic then you can zoom in on it.
    Shared album - Scott R - Google Photos
  8. #8 Re: Help me choose my meth
    Sep 2014
    Richmond Virginia
    is it on the front side nearish the boost control diaphragm?
  9. #9 Re: Help me choose my meth
    better pic of it. its hidden behind the harness there. Shared album - Scott R - Google Photos
  10. #10 Re: Help me choose my meth
    Sep 2014
    Richmond Virginia
    That seems pretty simple to install . where did you mount the tank?
  11. #11 Re: Help me choose my meth
    in the trunk. pump is next to it.
  12. #12 Re: Help me choose my meth
  13. #13 Re: Help me choose my meth
    Kemmerer, Wyoming
    I went with a gen 5 blower, which you will notice has space for the nozzle, while the gen 3 doesn't. if you want to use methanol on a gen 3, just go with a throttle body spacer or something like that. I also recommend doing the 50/50 blend to gain the full benefit of each component ( water and methanol). I had the most success with the biggest nozzle, but if your car bogs down, you will need to run a smaller nozzle. 1000 cc's is what I ran.
  14. #14 Re: Help me choose my meth
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by SgtMarshal View Post
    I just took a look and it seems like i have space where scotty put his.
  1. Which do i choose
    By 04lss in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-09-2019, 06:12 PM
  2. Why did you choose to buy a GP?
    By born2pdl in forum General Grand Prix Discussion
    Last Post: 12-30-2015, 08:18 PM
  3. which cam would you choose
    By Cobras 98 Prix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2012, 12:31 PM
  4. I can't choose; so you should choose for me
    By mousemonster1232 in forum General Tech Discussion
    Last Post: 02-22-2011, 04:57 PM
  5. Help me choose!
    By Bedwards in forum Tires & Wheels
    Last Post: 02-22-2010, 08:35 PM
