Thread: roller rockers ?
Results 1 to 16 of 16
  1. #1 roller rockers ?
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    if i was to go with a set of roller rockers w/the mods i have plus a intake . what size would be best to go with ?
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  2. #2 Re: roller rockers ?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    1.9 modded stocker from ZZP. I had them on my car and just ordered a set for my sons GTP
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: roller rockers ?
    Milpitas , Ca.
    what kind of performance gains did you get from them ? did you feel the difference ? did you have to get anything else ? springs , ect ????
  4. #4 Re: roller rockers ?
    Milpitas , Ca.
    now between the modded 1.9 stockers($300) and the 1.9 alum. roller rockers($400) what is the big difference ? would they be worth the extra $100 ?
  5. #5 Re: roller rockers ?
    St Louis MO
    Quote Originally Posted by bayareagtp View Post
    If ZZP still has their sale, you can get any of the rockers, +$1 for springs, +$1 for retainers, +$1 for the rocker install kit. However, if the sale is not still on even with the modded stockers you should buy some new (reusable from PRJ) rocker bolts and valve cover gaskets.
    If you get 1.9 rollers you would have to change out springs and retainer too, some recommend pushrods. I beleive I heard they are harded on the timing chain tensioner and with an old one that may be a bad thing.
    I can't imagine there is much (5) HP difference between the 1.9 modded and 1.9 RR.
    Yes you can feel a difference at the top end where the rockers come in to play. Probably good for 20 HP.
    2010 Camaro SS LS3
  6. #6 Re: roller rockers ?
    Milpitas , Ca.
    nice . yea it sounds like the modded 1.9 rockers are going to be my choice . thanks .
  7. #7 Re: roller rockers ?
    With the rollers you really need to upgrade springs, etc. So the diff is much more than $100.
  8. #8 Re: roller rockers ?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Do you ever plan to cam?
  9. #9 Re: roller rockers ?
    Milpitas , Ca.
    no nothing that major just rockers and mostly bolt ons . maybe later if i blow up this engine or when it goes out i will rebuild another with heads , cams and the works but until then i would rather do bolt ons .
  10. #10 Re: roller rockers ?
    Las Cruces, NM
    Look at the YellaTerra Kits from INTENSE. $400 but come with new rods, then you just need LS6 springs and valve cover gaskets. So about $500 for a great setup.
  11. #11 Re: roller rockers ?
    Donating Users bgn87's Avatar
    Kinnelon, NJ
    I was a victim of the old Intense 1.9's that were wearing on the sides. I ended up getting the 1.8 Comp Cams Pro Magnum roller tip rockers and really didn't notice any difference between the 1.8 and 1.9. What's nice with the Comps is that even though they are steel, they are actually lighter at the roller tip because there is less mass at the tip than the aluminum rockers. I run the LS6 springs with them.
  12. #12 Re: roller rockers ?
    Milpitas , Ca.
    nice i think i have a couple ideas now to go with . keep them coming if anyone has any other help with rockers .
    thanks !
  1. Rockers and Pacesetters at the same time??
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2008, 09:35 PM
