Thread: 2004 GTP Comp G .... P0136 and P0137 codes
Results 1 to 4 of 4
  1. #1 2004 GTP Comp G .... P0136 and P0137 codes
    Nov 2012
    Tracy, CA
    P0136 = O2 circuit [Bank1, sensor 2]
    P0137 = O2 circuit low voltage [Bank1, sensor2]
    For the P0137 code, my scanner had….
    Fuel Sys 1 CL
    Calc LOAD(%) 7.8
    ECT(F) 194
    STFT B1 (%) 0
    LTFT B1 (%) -25.0
    I replaced the downstream (under car) O2 sensor with a genuine, new AC Delco part about 2 years ago after I was getting the P0137 code. A few months ago I started getting P0136 and P0137 codes. Could that sensor have gone bad that fast ? I have been clearing the codes in hopes that the long highway drives I have been doing would clear things up. Fat Chance !! Any ideas on how to troubleshoot what’s going on or should I just buy another sensor and put it in…. I don’t recall ever changing the upstream sensor. Could that have anything to do with it ? Thanks…
  2. #2 Re: 2004 GTP Comp G .... P0136 and P0137 codes
    The front o2 sensor won't have anything to do with a low voltage code on the rear sensor.
    I'd check fuses and the wiring on the harness. If that checks out then it's possible the sensor is at fault.
  3. #3 Re: 2004 GTP Comp G .... P0136 and P0137 codes
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    Same, check fuses and wires, and be sure to put some di-electric grease inside the plug when you're re-connecting the harness.
    Alternate option would be to put an extension before the sensor to reduce the chance of fouling. ZZP and many other place have them.
    LINK - O2 Bung Extender – ZZPerformance
  4. #4 Re: 2004 GTP Comp G .... P0136 and P0137 codes
    Nov 2012
    Tracy, CA
    Thanks guys. I will check all the wiring and the plug at the O2 sensor. I will use some Di-electric grease on it too.
    I'll chek back in after I do those things, but it may be awhile with this damn Chinese Virus bs going on.....
    What a nightmare scenario for all of us..... I am hoping it's more media hyoe than reality for 90% of the country and world !
  1. Stumped with p1133 and p0137
    By chris99gtp in forum General Tech Discussion
    Last Post: 06-25-2015, 06:37 PM
  2. P0053 & P0136 code help
    By fmayo in forum PCM Tuning
    Last Post: 07-24-2014, 06:12 AM
  3. P0137 code after sd header install
    By GrandPrix06GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2013, 08:21 PM
  4. P0420 & P0136 Problem and How I fixed it
    By brised in forum General Grand Prix Discussion
    Last Post: 08-08-2012, 01:24 AM
  5. P0137, P0327 codes question
    By GTLGDP in forum General Tech Discussion
    Last Post: 12-16-2011, 03:38 PM
