did you mean fuel rail port? has no gas pressure?
id try a volt meter on the battery engine running, see what its putting out. check all the battery cables too. the thin one alt to fuse box too.
if you see bare wire at the end good chance that cable is bad.
also load test the battery, it could be on its last legs. parts stores cant test the voltage and load test for free.
