Thread: FMHE Install - VW Rad -Help Please
Results 1 to 8 of 8
  1. #1 Re: FMHE Install - VW Rad -Help Please
    you need the hood latch part secured some how. or the hood can blow open on you.
    my ic came used, had this bar that has threads end caps and fits and gets bolted between the rad support, i had to cut the bottom part off the bracket then welded it to the bar, bar also has two tabs to mount the frozen boost 101 fmhe to it, then the bottom of it a bolted to the bottom of the rad support where that bracket was bolted in. i re used the bolts and nut clips drilled new holes of course....yes nail biter. i did slip some thin ply wood in front of the ac condenser and rad.
    link to my ic install for any insight it might stir up for ya. theres two pages in this folder.
    scottydoggs's Library | Photobucket
    FMHE Install - VW Rad -Help Please Attached Images
  1. FMHE stage 4 install.
    By TDCRacing in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2014, 10:44 PM
  2. How to install ZZP FMHE and wire Intercooler Pump
    By Lsick7 in forum How To Write-Ups/Tech Tips
    Last Post: 02-19-2013, 12:15 PM
  3. Desert Fox transmission cooler install.....and FMHE???
    By copgtp in forum General Tech Discussion
    Last Post: 06-25-2011, 09:52 PM
  4. ZZP FMHE install and pics?
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 02:59 AM
