Thread: Went into Low Engine Power mode
Results 1 to 14 of 14
  1. #1 Re: Went into Low Engine Power mode
    SE Level Member LouF's Avatar
    Oct 2011
    Ohio
    the one up top is tucked inside the support, if you take the dog bone mounts off the support you'll find it.
    OK, will go do.
    2005 Grand Prix GTP
  2. #2 Re: Went into Low Engine Power mode
    Oct 2011
    Ohio
    Quote Originally Posted by LouF View Post
    OK, will go do.
    There are no wiring harnesses high or low. I took out the fans and looked behind radiator and condenser coil to be absolutely sure - nothing. - cleaned lots of grit and grime from the radiator.
    This must be some strange coincidence. I moved the car twice before going on this longer test drive when the malfunction occurred, so that can make sense.
    2005 Grand Prix GTP
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. 16:1 afr in power enrichment mode
    By copperpacecar in forum General Tech Discussion
    Last Post: 03-19-2012, 03:22 PM
  3. Engine Power
    By mongoclark in forum Engine
    Last Post: 01-18-2012, 12:52 PM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. No engine power above 2-3K?
    By scottm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2009, 02:58 AM
