Quote Originally Posted by 04lss View Post
Yeah I totally get that the trans is going to blow. Im keeping that tally seperate from here. I thought meth allowd about a .5 pulley drop. My plan is to run 80lbs since im doing e85.
meth let me go from a 3.2 on 93 gas, rockers 42 injectors, ported heads, fsic, added meth, dropped to a 2.8 and 21ยบ wot timing. up from 14.
since the gen 5 and n* swap i just did, my injectors maxed out on the 2.8 with gen 5, so i had to pulley up to a 3.0, since that blower swap my car feels every bit of 300 hp now. traction is like not there at all. and i make the same boost. 13 ish. the 2.8 made 15 at 5300 rpm on the gen 5. i had to let off i was still tuning in my maf. but the scan showed the injectors were over 100%....bummer, if i got 60 lb injectors i bet i could go 2.7 or 2.6 easy.
