no breather. you could run a line vc to tb. but if you got a ic with working pcv, make sure the holes are clear.
if its the pcv the sound you hear is coming from the crank seal. its sucking in air. taking the oil cap off will make it go away , if yo uput your hand over the hole, you will feel it sucking on your hand...engine running of course.
