I have the resivor where the airbox is then going down to the top port of the pump in the fender well the connector is touching the air deflector on the bottom so I cant bring it much lower then from the port on the side of the pump it goes to the bottom of the front mount then from the top of the front mount to the plate under the supercharger then from that to the coolant bottle is this an okay setup
