Thread: intercooler budget build shortstack
Page 8 of 8 FirstFirst ... 678
Results 141 to 144 of 144
  1. #141 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Going to pick up a oil filler tube at the store and tap a line into that and put it between the cap and valve cover
  2. #142 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Does the hose have to be big I was going to go with 3/8 diameter?
  3. #143 Re: intercooler budget build shortstack
    How to get PCV to work instead of valve cover breather! heres the how to on this topic. looks like a 3/8th hose they use.
  4. #144 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    problem solved got some marine weld also when getting the parts to fix this issue so I will hopefully be able to complete the intercooler setup this weekend
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  1. Replies: 399
    Last Post: 08-17-2016, 01:35 PM
  2. Super cheap intercooler build. Running total $275
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2013, 12:20 PM
  3. 12 sec budget GTP
    By TwinV6GTP in forum Track Sessions and Kills
    Last Post: 06-11-2013, 09:20 AM
  4. Cam + Intercooler Deployment Build
    By sdavis11b in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2011, 08:57 PM
  5. engine build on a budget....
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2009, 10:16 PM
