Thread: 255 lph walbro problems
Results 1 to 19 of 19
  1. #1 255 lph walbro problems
    Jul 2017
    macomb mi
    hey everyone about 5 months ago I installed a used 255 walbro and today I think it just left me stranded at the gas station. drove to the gas station fine stopped to get gas on the way to work then when I went to start it back up (moments after it was just running fine) it wouldn't start turned down my radio and noticed I couldn't hear the pump running. did I install this wrong? I heard these pumps last for a while or do you think it just gave out since it was used? only reason I ask if I installed it right is I did the tophat venturi swap since im a 04+ and its a venturi pump. ive seen people bend the 85 pin on the relay to solve this issue so ill try that when I get home but will most likely be ordering a pump. pump has run great for the 5 months and about 6k or 7k miles.
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  2. #2 Re: 255 lph walbro problems
    Jul 2017
    macomb mi
    Turns out the connected from the pump into the top hat melted omw to pick up a new one now. Did the connector just get old or was this improper installation? Please let me know so I can fix it right this time?
  3. #3 Re: 255 lph walbro problems
    Kemmerer, Wyoming
    did you do the fuel pump rewire?
  4. #4 Re: 255 lph walbro problems
    Jul 2017
    macomb mi
    Yes I did the zzp brand noticed it was the ground wire that melted as well if it matter for diagnosis
  5. #5 Re: 255 lph walbro problems
    The Boss Iceman6669's Avatar
    Jun 2011
    Ive seen those melt quite often. When I did the 255 pump myself I wired the pump up directly. I bypassed the plug all together for the pump power and return. I only used that plug for the sending unit.
    2011 F-150 Yote powered
  6. #6 Re: 255 lph walbro problems
    Jul 2017
    macomb mi
    sounds like a good idea since i have to go to the junkyard tomorow to get the connector. so how did you plug up the hole left by the connector in the top hat?(that one is the one that burned up for me, the one with the oring around it)
  7. #7 Re: 255 lph walbro problems
    Jun 2011
  8. #8 Re: 255 lph walbro problems
    Jun 2011
    Those were the best pics I have.... Its been MANY years since I did that.
  9. #9 Re: 255 lph walbro problems
    Jun 2011
    I let the connector there... I just didnt use the hot and return for the pump. The connector still fed power to and from the sending unit. I drilled two little holes and ran hot and return for the pump and sealed them with RTV.
  10. #10 Re: 255 lph walbro problems
    Jul 2017
    macomb mi
    Thanks for the pics I can see everything only thing is I have some type of sensor where you drill the holes so it will be a bit tighter for me by I just ended up getting the connector at the junkyard got a new top hat clamp thingy too old one was so rusty I couldnt get it on but I noticed the old connector was dirty I assume from the rusty top hat and me banging on it to seal it all that rust went right into the connector so hopefully that was the reason but I'll leave it be for now maybe I'll try this in the summer time lol
  11. #11 Re: 255 lph walbro problems
    Jul 2017
    macomb mi
    car didn't start this morning couldn't hear the pump probably melted the connector again. at least it died at my apartment but wish it gave me more time lol looks like im wiring it up "billboost" style lol just some quick questions would it be better to use clearweld instead of rtv? I have some left over its like a quick setting rubbery jbweld. just worried about the rtv coming loose and then not sealing.also should I add a fuse near the tank just incase the wire does melt it dosent melt somewhere in my carpet starting a fire? or will it not be a problem running a straight wire from the pump to the fuse box? sorry don't know much about electronics obviously I was stupid enough to think a new connector would fix the problem
  12. #12 Re: 255 lph walbro problems
    Jul 2017
    macomb mi
    so I didn't get a chance to look inside the actual fuel pump but I took the door off and the connector looked fine? do you guys think maybe the wire melted in the canister or may I actually have a bad pump now? im at work now and didn't get a chance to pull the canister out. deciding if I should order a new pump now. I feel like its a the pump but at the same time it didn't show any signs of fatigue I was literally driving going 80mph for an hour home from school with some small blips of 90mph and ran great. then parked it went to sleep tried to auto start it in the morning and next thing I know the fuel pump isn't making noise. let me know if I should buy one also I have the venture setup should I stick with walbroh or something else.
  13. #13 Re: 255 lph walbro problems
    Jul 2017
    macomb mi
    Browser no longer supported
    here is what i did for anybody reading this and needing it for the future i wish i wouldve dont this first thing but now im a master at doing the fuel pump so i cant complain.
  14. #14 Re: 255 lph walbro problems
    Kemmerer, Wyoming
    404. That’s an error.
    The requested URL was not found on this server. That’s all we know.
  15. #15 Re: 255 lph walbro problems
    Jul 2017
    macomb mi
  16. #16 Re: 255 lph walbro problems
    Jul 2017
    macomb mi
    Im now stuck in the menards parking lot 25 min away from home and I dont hear the fuel pump running checked fuses and changed relays is it safe to say this pump is ****ed?
  17. #17 Re: 255 lph walbro problems
    Jul 2017
    macomb mi
    When I try to prime it there is no fuel but when I start it. It will run for a quick sec and die like it was given one quick shot of fuel and thats it
  18. #18 Re: 255 lph walbro problems
    Jul 2017
    macomb mi
    I'm feeling like giving up on this car this is the third time this ****ing pump has stopped working on me in 3 months like why is this thing such a problem I dont understand how no one else is having this issue with walbroh unless the ****ers I bought it from just gave me some offbrand **** ****
  19. #19 Re: 255 lph walbro problems
    Jul 2017
    macomb mi
    can someone link a thread of what pump to get im busy most of the weekend and dont feel like hunting one down. can i get any on amazon so i can get fast free shipping?
  1. Walbro 255 part number.
    By BoostedPontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 11:15 PM
  2. walbro fuel pump
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2015, 09:22 AM
  3. Walbro 455?? No start
    By conner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2015, 10:17 AM
  4. 60# injectors and walbro
    By Ultra440 in forum For Sale - Parts
    Last Post: 03-28-2014, 09:41 AM
  5. racetronix walbro w1 help
    By mskram1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-30-2012, 11:07 AM
