Thread: Where does this bolt go
Results 21 to 40 of 62
  1. #21 Re: Where does this bolt go
  2. #22 Re: Where does this bolt go
    Sep 2017
    Texas
    Oh okay, which one gets left open? All the vacuum lines are hooked up
  3. #23 Re: Where does this bolt go
    the you never touched, stays open, theres two on the right side, leave that one open. its got a funky clip on it too, there used to be a foam cap over it, its long gone and not a issue.
  4. #24 Re: Where does this bolt go
    Sep 2017
    Texas
    Okay awesome, thank you so much for your help on this, I'll go back up there and hope for no codes
  5. #25 Re: Where does this bolt go
    its a small plug that goes to the little box there with the two vac lines, make sure its plugged in.
  6. #26 Re: Where does this bolt go
    Sep 2017
    Texas
    I made sure it was plugged in, hopefully it passes inspection
  7. #27 Re: Where does this bolt go
    your gonna need to put some mile son it so all systems show ready. you can see this in the t app or a hand held scanner, looking for "im readyness" once all them show ready, your clear to go to inspection.
  8. #28 Re: Where does this bolt go
    Sep 2017
    Texas
    Okay awesome, well I went and noticed my check engine light doesn't come on at all. Could that be the 1671 code?
  9. #29 Re: Where does this bolt go
    P1671 - GM Forum - Buick, Cadillac, Olds, GMC & Pontiac chat yeah that means the cel light is not working you fill fail inspection for that one.
  10. #30 Re: Where does this bolt go
    Sep 2017
    Texas
    Dangit, lol looks like I got another job today
  11. #31 Re: Where does this bolt go
    Sep 2017
    Texas
    Well I just took it off and I have no security or check engine light even installed
  12. #32 Re: Where does this bolt go
    when you turn the key to run all the dummy lights should come on. some times its the bulb went dead, a cluster swap would be easy enough if your not a soldering guy.
  13. #33 Re: Where does this bolt go
    Sep 2017
    Texas
    So their was no bulbs at all, to install a new bulb would I need a new cluster?
  14. #34 Re: Where does this bolt go
    theres a bulb, its a little led thats soldered in the board. i dont know much more then that on the topic.
    jy cluster should fix it tho.
  15. #35 Re: Where does this bolt go
    Sep 2017
    Texas
    Alright I'll go check out the junkyard in a little bit and get one. Thank you for your help on this journey lol
  16. #36 Re: Where does this bolt go
    with any luck its the last thing you need done for a while.
  17. #37 Re: Where does this bolt go
    Sep 2017
    Texas
    I hope so also, I'll be going to tomorrow so looks like I'll be doing the water deflector now instead
  18. #38 Re: Where does this bolt go
    St. Louis
    The CEL on a 98 is an LED? I know the one on my 00 GT died and it was just a regular replaceable bulb.
  19. #39 Re: Where does this bolt go
    it maybe a very small bulb, but its still soldered in the board is is not? back lighting bulbs are the easy ones to change.
  20. #40 Re: Where does this bolt go
    St. Louis
    Probably. I don't remember for sure and it's far too cold to go pull it again. I want to say it was smaller than the normal 194's though.
    Edit- here's a post that may help--> My service engine soon bulb is burned out?
  1. What is this bolt?
    By mhunt in forum Introductions/Noob Questions
    Last Post: 12-19-2016, 12:18 PM
  2. Grand Prix vs Subaru WRX [Bolt ons] and Mitsubishi EVO [Bolt ons] [Videos]
    By ADrugDealer in forum Track Sessions and Kills
    Last Post: 05-06-2014, 12:02 PM
  3. Bolt ons!?!?!?!?!?!
    By clodracer2000 in forum Engine
    Last Post: 12-05-2012, 02:04 AM
  4. WTB: Bolt in TOG dp.
    By glanzergtx in forum Wanted To Buy - Parts
    Last Post: 02-28-2012, 09:55 PM
  5. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
