I have my intake manifold off to do the Lim and forgot where the double ended bolt goes, I have it in the main old bolts so I know it goes with them
I was thinking it was by the rear driver side of it but it was too long. Non of mine where hex bolts though
Opps sorry I was thinking Allen head, yeah I have noticed 3/8ths has fit better. I thought I was going crazy when the 10mm was loosening it
So now I have another part where I cant remember where it goes, I found out the bolt was for the thermostat housing. Now I have the vacuum line from the T on the intake manifold hanging and can't remember where it bolts too
Okay awesome I believe it's the map sensor then, thank you very much
Got everything together, and got it running, then about 5 minutes later when waiting to finish filling up the radiator all the coolant ran out the bottom from somewhere. One thing done another happens
I have a 98 so I only have one elbow and I did those also, I did the metal ones. The leak is coming from the lower front some where I believe, I'll be trying to find it tomorrow
I never opened the petcock, I took off the lower coolant hose
So got her scanned and got back code p1671, it's a new code didn't have it before she went down a few months ago
I forgot to plug in my intake air temperature sensor, I'll go back over the car check every
Okay good I'll go back up there and have it ready checked
So I just looked at my boost bypass solenoid and where it has the two nozzles on one side only one of them is hooked up, where does the other go too?
