Thread: Where does this bolt go
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
  1. #1 Where does this bolt go
    Sep 2017
    Texas
    I have my intake manifold off to do the Lim and forgot where the double ended bolt goes, I have it in the main old bolts so I know it goes with them
  2. #2 Re: Where does this bolt go
    likely the outer edge of the lim where you might have had a wire clipped to it or something. pretty sure all of mine are just hex heads, no stud action going on.
  3. #3 Re: Where does this bolt go
    Sep 2017
    Texas
    I was thinking it was by the rear driver side of it but it was too long. Non of mine where hex bolts though
  4. #4 Re: Where does this bolt go
    a 6 sided bolt is a hex is is it not? they are 3/8 ths or 10 mm. 3/8 ths fits better.
  5. #5 Re: Where does this bolt go
    Sep 2017
    Texas
    Opps sorry I was thinking Allen head, yeah I have noticed 3/8ths has fit better. I thought I was going crazy when the 10mm was loosening it
  6. #6 Re: Where does this bolt go
    Sep 2017
    Texas
    So now I have another part where I cant remember where it goes, I found out the bolt was for the thermostat housing. Now I have the vacuum line from the T on the intake manifold hanging and can't remember where it bolts too
  7. #7 Re: Where does this bolt go
    T under the snout splits to the fpr and the back side to the map sensor.
  8. #8 Re: Where does this bolt go
    Sep 2017
    Texas
    Okay awesome I believe it's the map sensor then, thank you very much
  9. #9 Re: Where does this bolt go
    Sep 2017
    Texas
    Got everything together, and got it running, then about 5 minutes later when waiting to finish filling up the radiator all the coolant ran out the bottom from somewhere. One thing done another happens
  10. #10 Re: Where does this bolt go
    you do elbows too?
  11. #11 Re: Where does this bolt go
    Sep 2017
    Texas
    I have a 98 so I only have one elbow and I did those also, I did the metal ones. The leak is coming from the lower front some where I believe, I'll be trying to find it tomorrow
  12. #12 Re: Where does this bolt go
    Did you leave petcock open?
  13. #13 Re: Where does this bolt go
    Sep 2017
    Texas
    I never opened the petcock, I took off the lower coolant hose
  14. #14 Re: Where does this bolt go
    Sep 2017
    Texas
    So got her scanned and got back code p1671, it's a new code didn't have it before she went down a few months ago
  15. #15 Re: Where does this bolt go
    you forget to plug in the boost bypass actuator? thing under the fat round thing on the super charger tb, rad side.
    got the vac line back on it too?
  16. #16 Re: Where does this bolt go
    Sep 2017
    Texas
    I forgot to plug in my intake air temperature sensor, I'll go back over the car check every
  17. #17 Re: Where does this bolt go
    yeah code was for low voltage, or no voltage, aka not plugged in is my first thought.
  18. #18 Re: Where does this bolt go
    Sep 2017
    Texas
    Okay good I'll go back up there and have it ready checked
  19. #19 Re: Where does this bolt go
    Sep 2017
    Texas
    So I just looked at my boost bypass solenoid and where it has the two nozzles on one side only one of them is hooked up, where does the other go too?
  20. #20 Re: Where does this bolt go
    the side with two holes gets the one hose only, the other is left open, the single on on the left side goes to the t under the snout and the fpr.
  1. What is this bolt?
    By mhunt in forum Introductions/Noob Questions
    Last Post: 12-19-2016, 12:18 PM
  2. Grand Prix vs Subaru WRX [Bolt ons] and Mitsubishi EVO [Bolt ons] [Videos]
    By ADrugDealer in forum Track Sessions and Kills
    Last Post: 05-06-2014, 12:02 PM
  3. Bolt ons!?!?!?!?!?!
    By clodracer2000 in forum Engine
    Last Post: 12-05-2012, 02:04 AM
  4. WTB: Bolt in TOG dp.
    By glanzergtx in forum Wanted To Buy - Parts
    Last Post: 02-28-2012, 09:55 PM
  5. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
