http://i1097.photobucket.com/albums/...b/limjob11.jpg
Oh okay, which one gets left open? All the vacuum lines are hooked up
the you never touched, stays open, theres two on the right side, leave that one open. its got a funky clip on it too, there used to be a foam cap over it, its long gone and not a issue.
Okay awesome, thank you so much for your help on this, I'll go back up there and hope for no codes
its a small plug that goes to the little box there with the two vac lines, make sure its plugged in.
I made sure it was plugged in, hopefully it passes inspection
your gonna need to put some mile son it so all systems show ready. you can see this in the t app or a hand held scanner, looking for "im readyness" once all them show ready, your clear to go to inspection.
Okay awesome, well I went and noticed my check engine light doesn't come on at all. Could that be the 1671 code?
P1671 - GM Forum - Buick, Cadillac, Olds, GMC & Pontiac chat yeah that means the cel light is not working you fill fail inspection for that one.
Dangit, lol looks like I got another job today
Well I just took it off and I have no security or check engine light even installed
when you turn the key to run all the dummy lights should come on. some times its the bulb went dead, a cluster swap would be easy enough if your not a soldering guy.
So their was no bulbs at all, to install a new bulb would I need a new cluster?
theres a bulb, its a little led thats soldered in the board. i dont know much more then that on the topic.
jy cluster should fix it tho.
Alright I'll go check out the junkyard in a little bit and get one. Thank you for your help on this journey lol
with any luck its the last thing you need done for a while.
I hope so also, I'll be going to tomorrow so looks like I'll be doing the water deflector now instead
The CEL on a 98 is an LED? I know the one on my 00 GT died and it was just a regular replaceable bulb.
it maybe a very small bulb, but its still soldered in the board is is not? back lighting bulbs are the easy ones to change.
Probably. I don't remember for sure and it's far too cold to go pull it again. I want to say it was smaller than the normal 194's though.
Edit- here's a post that may help--> My service engine soon bulb is burned out?
