Thread: Engine noise, rod Knock or something else?
Results 1 to 6 of 6
  1. #1 Engine noise, rod Knock or something else?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Hi all,
    I bought a Regal GS a few days ago. When its cold it sounds like it has a bottom end noise. I took a video of it cold. After listening more closes i wonder if it isnt something else, like maybe a bad tension-er pulley.
    20181125_223517.mp4 - Google Drive
    The noise can be heard at the end of the video very clearly. ( I just added the video so it may be a bit before it finishes converting.)
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: Engine noise, rod Knock or something else?
    take the sc belt off first, run it. if sound is still there, take the other belt off, run it. see if its gone. sounds like a pulley maybe.
  3. #3 Re: Engine noise, rod Knock or something else?
    Sep 2014
    Richmond Virginia
    That would be ideal! Now that i think about it, it seems too irregular to be a rod knock but who knows.
  4. #4 Re: Engine noise, rod Knock or something else?
    Yeah def in the accessory it's too fast to be in the engine.
  5. #5 Re: Engine noise, rod Knock or something else?
    HUDSON
    Possibly a cracked flexplate.
  6. #6 Re: Engine noise, rod Knock or something else?
    Sep 2014
    Richmond Virginia
    Welp,
    Just got back from having it on a lift at the shop where my dad works. They sell a lot of early 2000s cars there. We listened all over the car with a mechanics stethoscope . We could not find any bottom end noise. There also wasnt any abnormal pulley noise.
    We believe that the noise is a faulty timing chain tensioner. The knocking is farly obvious around 1300 rpm so i held it there while pop checked the bottom end with the scope.
    I also had the trans scanned, and we dont think there is anything wrong with it either. The stater pump is noisy but that is all. I am going to run some "Trans-X" through it and call it a day.
  1. Replies: 10
    Last Post: 09-16-2012, 09:05 PM
  2. Need help engine knock??
    By thomasd2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2012, 04:34 PM
  3. Replies: 21
    Last Post: 05-08-2012, 10:32 AM
  4. not rod knock but terrible noise
    By pontiacgtp98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 08:58 PM
  5. L36 engine noise.. rod knock?
    By gpgt98 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-23-2011, 08:58 AM
