BillBoost37
Nope..
None of us are that lucky. There's a possibility you clipped the edge of the wire when you pulled the side cover and redid that seal. The other thing I see happening here is something went wrong in the rebuild and theres a little metal on the sensor (you did pull it and wipe any metal dust off it, right?).
My suggestion would be to test the sensor based on the ohm reading in the ATSG manual (ask Scotty if you don't have it). Then pull the side cover, inspect the internal wiring harness and pull the sensor. Maybe replace it just in case.
