Thread: Starting Problem.. Cranks with fuel but no start. Injector Circuit open all cylinder
Results 1 to 3 of 3
  1. #1 Starting Problem.. Cranks with fuel but no start. Injector Circuit open all cylinder
    Oct 2018
    iowa
    My 2004 Grand Prix won't start it throws 10 codes. H02S P0030 Heater Control Circuit Bank 1 Sensor 1, H02S P0036 Heater Control Circuit Bank 1 Sensor 2, P0201 Injector Circuit 1 open cylinder 1, P0202 Injector Circuit 2 open cylinder 2, P0203 Injector Circuit 3 open cylinder 3, P0204 Injector Circuit 4 open cylinder 4, P0205 Injector Circuit 5 open cylinder 5, P0206 Injector Circuit 6 open cylinder 6, P0443 Evaporative Emission System Purge Control Valve Circuit, I find it hard to believe all injectors are bad but dont know where to go from here
    I also have a new fuel pump in it.
  2. #2 Re: Starting Problem.. Cranks with fuel but no start. Injector Circuit open all cylin
    id check over the wire harness to the injectors and o2 sensor and evap, its all in the same place. if this all happened at once could be a worn through wire or two.
  3. #3 Re: Starting Problem.. Cranks with fuel but no start. Injector Circuit open all cylin
    Oct 2018
    iowa
    now i got it to start finally but then it died after 4 seconds and wont start again
  1. I have spark, fuel and it cranks but no start
    By YeahRight in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2023, 09:20 PM
  2. Replies: 6
    Last Post: 07-20-2021, 09:27 PM
  3. Car cranks but no start. Fuel injectors not releasing gas
    By Shiftingshaddow in forum General Tech Discussion
    Last Post: 04-20-2016, 06:58 AM
  4. starting problem. when go to start the engine will sometimes die
    By DirtDog in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2012, 12:32 PM
  5. Cranks for a long time before starting, pump or regulator?
    By MTchevy1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2011, 08:18 AM
