Thread: Spring install without an air compressor???
Results 1 to 10 of 10
  1. #1 Spring install without an air compressor???
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Finishing up a cam install and wanna install my 90# springs since i have everything off. Are there any other ways of install the springs other than using a compressor?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Spring install without a compressor???
    ive only heard of feeding string into the cylinder via the plug hole, then hand turning the engine and driving the piston up to hold the valves in, cant see that being easy.
  3. #3 Re: Spring install without an air compressor???
    Kansas
    Head removal.
  4. #4 Re: Spring install without an air compressor???
    SE Level Member destroyer85golf's Avatar
    Aug 2012
    Hillsdale Illinois
    Not to be a debbie downer here but, If it were me i wouldnt even attempt it without air. All it takes is one valve out of twelve to drop down into the cylinder and guess who's doing a head gasket...... if you dont have a air compressor maybe you can borrow a air pig from someone and use that??
    2000 GTP daytona 500
  5. #5 Re: Spring install without an air compressor???
    Your best bet would be to remove the heads...unless you can borrow a compressor or keep the stock valvetrain for the vs cam.
    04 Comp G.
  6. #6 Re: Spring install without an air compressor???
    Mar 2012
    NC
    Just go buy a cheap air compressor. It won't take a lot of pressure to keep the valves closed.
  7. #7 Re: Spring install without an air compressor???
    rent one.
  8. #8 Re: Spring install without an air compressor???
    Bowie, MD
    Is it safe to run the stock valves with the vs cam untill I can get a chance to install the 90# springs?
  9. #9 Re: Spring install without an air compressor???
    I've done the spring/rope. It's not so bad.. not ideal, but not great. Just make sure you turn the motor to hold the valves with teh spring/piston. If not.. call me and I'll tell you exactly what tools are needed to fish a valve back up into the guide.
    First time is always a learning experience
    Ohio
    Honestly, all you need is a little roofers air compressor. Just a 3-5 gallon is enough to do the job
  1. Valve spring compressor
    By apierce1289 in forum General Grand Prix Discussion
    Last Post: 05-04-2012, 04:26 PM
  2. How do I? Valve Spring Compressor
    By Hixc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2012, 06:49 PM
  3. Compressor psi during valve spring replacement
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2011, 07:23 AM
  4. Valve spring air compressor tool
    Last Post: 04-22-2011, 09:53 PM
  5. Spring Change Tool for Use with Air Compressor
    By TeeWX in forum General Tech Discussion
    Last Post: 06-20-2010, 09:51 PM
