Thread: Coolant flush... Shop or diy?
Results 1 to 8 of 8
  1. #1 Coolant flush... Shop or diy?
    GT Level Member Jaredthefail's Avatar
    Nov 2015
    Olive branch, MS
    My dex cool looks like s**t and I heard it's better to switch to universal/green coolant. Would I benefit from getting a shop to do it or should I do it at home?
    Sent from my Moto G (5S) Plus using Tapatalk
  2. #2 Re: Coolant flush... Shop or diy?
    St. Louis
    Depends on how much time you have. If it looks bad, then you will likely have to flush it multiple times to get all the junk out. I did mine 3 times before it stayed clean when I switched to green. Don't forget to backflush the heater core too. I'm not sure how much a shop actually charges for one.
  3. #3 Re: Coolant flush... Shop or diy?
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Quote Originally Posted by Jaredthefail View Post
    A vote here for DIY. Prestone & Peak sell a cheap flush kit, you splice a tee into a heater hose and leave it there. Swapping in a new T-stat is smart too. Run for a while without one helps flush stuff better, I think. While you're in there, it's a good time to do hoses (rad & htr), easy and short money for peace of mind..... my 0.02...
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  4. #4 Re: Coolant flush... Shop or diy?
    GTP Level Member
    Oct 2014
    My guess is a shop is only going to do it once. DIY
  5. #5 Re: Coolant flush... Shop or diy?
    May 2016
    Rouge Island
    Quote Originally Posted by markpa View Post
    The 'quick lube' places sucker people with a "radiator flush & fill". Makes it sound good, still less than half the job.
  6. #6 Re: Coolant flush... Shop or diy?
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Do it yourself. Not too hard. If you are switching, I would dump it, fill up with water and some flush chemicals. Drive it for a day or so and dump again. Fill again with just water and drive for another day. See if it comes out clean when you dump it. If so, change hoses and fill with fresh coolant/water. If not keep repeating until the water comes out clean.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  7. Likes Jaredthefail liked this post
  8. #7 Re: Coolant flush... Shop or diy?
    St. Louis
    Also when you go to refill, use distilled water.
  9. #8 Re: Coolant flush... Shop or diy?
    You could do the "Bill" method.
    Drain it out and using your hose clamp tool (honestly go buy one) pull the heater hoses off, one at firewall the other at alternator bracket, top and bottom radiator hoses at radiator. Now take out your garden hose and prep to get wet. Put hose right into the open cap area of the radiator and fill it up. Move over to one of the heater hoses. Flush the core and engine, hook up to top hose or if you pulled t-stat the open LIM. Basically flush each and every orifice until it's running clean everywhere. Now hook back up, fill it back up and fire it up. Keep in mind you might have an air pocket in the LIM so watch the temp gauge and feel your top hose it should get warm quick enough. 3800's make good heat.
    Repeat.. drain and flush. Up to you how many times. You are going to get soaked and you'll get it clean. The block of a 3800 holds approximately a gallon after you've pulled then engine out etc.
  1. Coolant Flush
    By Logan541 in forum General Tech Discussion
    Last Post: 08-25-2015, 11:15 AM
  2. Coolant Flush
    By donjo in forum 5.3L V8 (LS4)
    Last Post: 08-05-2015, 05:22 PM
  3. Coolant Flush?
    By gahris in forum General Tech Discussion
    Last Post: 04-03-2010, 02:12 PM
  4. Coolant Flush twice?
    By nyydmb12 in forum 04+ Specifics
    Last Post: 02-14-2010, 08:17 PM
  5. Coolant Flush : How to?
    By 04CompG in forum General Tech Discussion
    Last Post: 03-09-2008, 08:35 AM
