Thread: 05 gtp noises from fusebox under hood and check engine light stays on when car is off
Results 1 to 16 of 16
  1. #1 05 gtp noises from fusebox under hood and check engine light stays on when car is off
    SE Level Member blakephxaz's Avatar
    Feb 2018
    Phoenix Arizona
    ok so my fuse box is making like a clicking noise i can hear in the throttle body and the p/train relay #40 and there is like a tapping or pulsing noise coming from the fuel pp relay #41 the noises stop if the relay is removed but check engine light stays on all the time the car is off and key is in my pocket any info would be appreciated thanks in advance
    2005 Pontiac grand prix gtp phx az first wbody car first time doing any mechanical work just plan new to this whole thing
  2. #2 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Have you tested the relay? How to Test a Relay the Correct Way - YouTube If not I'd start there. What check engine light is it throwing? Any trouble starting the car? Is the fuel pump running all the time?
  3. #3 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    Aug 2017
    Raytown, MO
    Any other issues? Battery draining?
  4. #4 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    Feb 2018
    Phoenix Arizona
    its draining myt battery i can still start and drive ,y car ill get back to u in a lil with the codes that i get
  5. #5 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    fuse box getting hot? it smell burnt? if so you need to take the box off the fender and open it to see the back side where all the wires go in. cars have caught fire from a bad fuse box. so unhook the battery when parked to be safe if you smell or feel heat from it.
  6. #6 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    Feb 2018
    Phoenix Arizona
    i don't think the box is getting hot the to relays r the p/train relay make the throttle body i think the part attatched to the sc click
  7. #7 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    Feb 2018
    Phoenix Arizona
    ok so i hooked up my scanner and heres what i got P0443, C0247, C0050 right rear wheel speed sensor, c0550 ecu performance
  8. #8 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    that last one means you need a new ebcm. it controls the brakes, makes sense now huh?
    the 443 is a evap code, the rest are abs related. bad ebcm could cause them.
  9. #9 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    Aug 2017
    Raytown, MO
    Scotty is on the money there. The problems could be unrelated though. Best way to tell if anything is shorting out and draining is to with the battery off, measure the current draw across the battery when charged, if it's above 500mA, you have a problem. You'd then want to pull most all the fuses and leave your multimeter hooked up and look every time you add a fuse. You'll see the amperage spike when the bad circuit's fuse is plugged in. Now you know what circuit to look for issues. I have most all wiring diagrams once you find the circuit.
    I would still start with checking the relay though.
  10. #10 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    Feb 2018
    Phoenix Arizona
    is the ebcm interchangeable with one from another car like can i go to the junk yard and pull one out of another car and just put it in mine or r they vin specific or would it need to be reprogrammed .
  11. #11 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    Aug 2017
    Raytown, MO
    Not sure on the later models like yours, but I'm 90% sure you have to have that programmed by the stealership for around $60-100.
  12. #12 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    theres no dealer bs for the ebcm, its mounted on the abs pump next to the master cylinder. snag a jy one swap it in there.
    or take yours off and send it out for repair or try to repair it your self if you ok with soldering a board some. seen a vid on how to fix the one in my tahoe, looks easy enough.
    you can take it off and still drive the car too.
    heres a how to, a 05 should be about the same looking. How To (Un)Install EBCM
  13. #13 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    Aug 2017
    Raytown, MO
    Lol sorry! Thanks for setting me straight Scotty! I knew this was the case for the older models like mine. Good to know!
    And yeah, I repaired mine using that method. Though it ended up showing even more codes! Haha ended up having to grab one anyhow.
  14. #14 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    97 is once again the odd ball year. my 98 has the same master and abs pump, my regal ebcm is in the d/s kick panel, in my case and a 97 id think you need the part# to match or it wont work.
  15. #15 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    Feb 2018
    Phoenix Arizona
    ok so i swaped out the ebcm and the abs lights and **** go off but come bak on every once in awhile when I'm driving but when i turn car off and back on later they r off again and with the fuse box making noise and my throttle body wirerless throttle contraption stoped making noise i fix that it was my oil level sensor wires were ****ed up and must of been sorting out or sumthing i put new connector on and pluged in after cleaning up the wires and whala!!
  16. #16 Re: 05 gtp noises from fusebox under hood and check engine light stays on when car is
    Aug 2017
    Raytown, MO
    Quote Originally Posted by blakephxaz View Post
    Interesting! Though looking at the schematics, they do share common sensor grounds so that makes sense. Hopefully that's all that was shorting! Glad you found the issue!
  1. Flashing check engine light and Low oil light?
    By Explicit_Spade in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2016, 01:54 PM
  2. Check tire pressure light stays on
    By Jonarin in forum General Grand Prix Discussion
    Last Post: 10-12-2014, 05:37 PM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  5. Engine light stays on - '99 GT
    By 149GP in forum General Tech Discussion
    Last Post: 09-17-2008, 11:15 PM
