Thread: Will not start after replcacing fuel rail and injectors
Results 1 to 20 of 136
  1. #1 Re: Will not start after replcacing fuel rail and injectors
    Quote Originally Posted by jetfighterv View Post
    Well actually that's true but I did take it off when I replaced the alternator so that's not the problem i forgot lol bc it started after I changed that any way to test if the injectors fire without being able to start the car?
    you must have missed all my text here a page back.
    if you got fuel it should at least try to start. if the vac line off it has gas in it, or smells of gas the fpr is bad.
    what are these new injectors? stock replacements?
    check for spark yet?
    side note, the injector harness can have a bad spot that you aggravated by taking the plugs off. so you can look for a break, or also test the power at the plug, test light works, or you can take a marker light out the head light and push it in the injector plug. you turn the key to run and the bulb should flash a few times, or the test light will flash if its got power. it only flashes a few times then you have to re cycle the key, its the prime for the engine to start. if it dont flash at all you got no power to them.
  2. #2 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    The bulbs I got don't fit for some reason I tried
  1. fuel rail/injectors
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2013, 02:58 PM
